sitheris
- Jul 30, 2004
I am looking to build a cheap Ubuntu server for the following purposes:
Fileserver (Samba)
Webserver
Webdav
FTP/SCP/SSH
Virtual Machines
Here's the hardware I've chosen so far:
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz Socket AM2 Processor Model ADO4000DDBOX - Retail $66.99
GIGABYTE GA-M61P-S3 AM2 NVIDIA GeForce 6100 ATX AMD Motherboard - Retail $74.99
G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model F2-6400PHU1-1GBNR - Retail (2) $79.98
HDD (OS) ??
HDD (Storage) - Seagate Barracuda 7200.10 ST3750640AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $209.99
PSU - ??
I have a case and DVD drive already, and the motherboard has onboard video/sound. My main concern is with the Disk setup. Should I use RAID or not? I would like to be able to back up my files somehow, so should I just add another 750gb drive and setup a cron job to do the backup? (Since I know RAID is not a backup solution).
Also, should I get a separate small drive for the OS or just make a partition off of the 750gb?
Finally, what kind of PSU do I need to run this, since I don't have a sound card or video card? I've heard it's better to have more watts than you need because it doesn't make the PSU work as hard, which in turn lowers heat dissipation. Also any recommendations on a quality yet affordable PSU would be great.
Budget is about 500-550 before tax and shipping and I'll probably add more storage later as I need it.
Fileserver (Samba)
Webserver
Webdav
FTP/SCP/SSH
Virtual Machines
HDD (OS) ??
PSU - ??
