- Oct 29, 2000
Hey all,
I've been a long term Nvidia user, but in my latest build I decided that AMD's offerings were a much better bang for the buck, so I decided to go with a 6970 crossfire setup.
There are a couple of things I haven't been able to figure out how to do with AMD's drivers that I used to with Nvidia's. I have googled this, but it has not been helpful. I figure I am just overlooking something dumb, so I turn to you guys for help in setting me straight.
1.) Application/Profiles
In Nvidias drivers I could set up specific settings that autoloaded when I launched a particular game. For instance, if I wanted to force vertical sync on for Civ 5, and force it off for Counter-Strike: Source I could pint the driver interface to each games respective executables, and set application specific settings for those games that would automatically override the global settings whenever I launched them. I ahven't been able to find this in the Catalyst Control Center. Is it there? Am I just overlooking something dumb? Help?
2.) Changing Crossfire Render Modes
It is a well known fact that AFR produces the best performance scaling with multiple GPU's but also introduces a significant amount of input lag. As an alternative to AFR, Nvidia offers SFR and AMD offers Scissor rendering and Supertiling.
In the Nvidia drivers it was easy to tell the drivers which mode to use for each game. I can't seem to find this option anywhere in the CCC. Again, is it there? Am I just overlooking something dumb? Help?
Much obliged!
--Matt
Much obliged!
--Matt
