- May 18, 1997
Really cool stuffs....or hot actually. Well depends how you look at it.
and how exactly do u find the temp with that?
What happens if you lap the CPU? Will the recess in the heat spreader have to be milled deeper? This idea looks gimmicky. If Intel was serious about actually having the user measure temps, then placing it directly inside the heat spreader would work out better.
The point is Tcase means little, it is the die temp we are really concerned with when OCing the chip.
Overclockers.com has been using a test setup like that for years....
http://www.overclockers.com/articles1312/
This isn't the first time something similar to this has been done. but so far, it seems to be the best (as in most professional) approach. While other sites have done similar, it *appears* as tho the groove was cut with a dremel (it just dont look clean enough to be done on a mill). The pics shown definately look like it was cut with a mill.
some past attempts to level the heatsink testing field have included using TEC's mounted on cpu sized/shaped metal plates (simulate an IHS) with the thermocouple buried in that. Use of the TEC's allowed more precise control of the amount of heat supplied by the 'cpu' to the heatsink, thus allowing for more precise measuring of the effeciency of the heatsink at removing it from the 'cpu'.
Good idea on using the same thermocouple and meter on every test, does remove one more possible area of error (well, reduces that error factor anyhow)
6/1011 = .59% thats POINT 59% I think we can not worry about that and since it is repeated for every heatsink, a constant of the test, it does not matter.
Calibration of the meter used to read the probe and no standard method of deteremining tightening torque of mounting hardware for heatsinks using nuts and screws and/or springs would be of much greater concern to the validity.
I'm not sure about that. Doesn't Intel report the maximum temp of the chip based on Tcase? If so, knowing the difference between the DTS temp and the Tcase temp would be very useful to help figure out a "safe" long-term temp for overclocking. Realizing that the difference between DTS temp and Tcase is likely to vary chip by chip, but at least you'd have a general idea. Right now, I don't know if anyone really knows how Tcase compares to DTS temp (and temp reported by programs like Coretemp).
Here's the link from Intel about maximum Tcase (near the bottom of the page):
http://www.intel.com/cd/channel/reseller/asmo-na/eng/299986.htm
