- Jan 18, 2007
So i didn't find any topic on this but i was curious. Looking through the Headphone pics thread i noticed alot of you get your cans recabled. So i ask, what exactly is the purpose of this and what are the benefits?
Your test was meaningless. Do a double-blind ABX test and get back to us. Or just continue to think the way you do, but realize that your test is meaningless. Placebo effect.
That certainly isn't true. While I'm of the group that believe that cable improvements yield benefits that are sometimes vastly minimal (and certainly inaudible in some cases), they can indeed yield audible improvements.Absolutely no difference can be heard, unless your cable is broken. And by no, I mean absolutely none, not the smallest amount. #2 needs to do some double blind A/B/X listening tests, anything less is meaningless.
LOL ... did I not say I did A / B tests!?
Yes, double blind with a random swapping of interlinks on each input after each test.
The pre-amp used had 5-inputs and we had two sources with three interlinks that night. Did these tests with Audio Technica AD900s and you could pick out the source (one source had 2 avail outs) and interlinks fairly easily after a few minutes of going back and forth.
The one point I want to make is that this is one of those things that will be never ending, you'll always hear about some other cable that's supposed to bring the world across at amazing clarity or whatever. You just GOTTA STOP SOMEWHERE.
I'd do some research and just stop at one cable... and call it done, it may be worthwhile improvement to your cans.
A/B doesn't inherently mean double blind. How exactly did you make the test double blind? So you could easily pick out all six different combinations of interlinks and sources in a double blind test? 100% of the time? How many times did you ABX? I find that pretty difficult to believe. A lot of the time audiophiles have trouble identifying the difference between things like amps and CD players in an DB ABX test, so being able to AB(C in this case)X interconnects infallibly seems like bunk.
So you don't even know what a double blind test is, but you're sure you did it. About what I figured. Your test wasn't double blind. I question whether it was even really single blind. And it wasn't an ABX test.
recabling may or may not make a difference in the sound quality. if there is a difference, it will be very slight, and may offer to balance out your set up (if needed).
with the differences so slight, I believe the money (plus an additional savings) is better spend on better gear, not just better cables.
of course, this is subjective, but better headphones will sound better and are generally more expensive. guys, we are dealing in vague generalities here, so don't go with bang-for-buck crap now. so save the recabling fee, sell you current headphones, put some extra cash down and you will be able to buy better headphones. Hopefully there will be no argument that they will sound better.
I'd like to try out silver-based interconnects as much as the next guy, but the artificially-devised pricing structures are intolerable. I'm not entire sure how the fine folks at Nordost, and other similar so-called "high end" cable manufacturers, are able to sleep at night.If you want to look at it scientifically *cough* Nicolaskl *cough* the distortion ratio in silver...is different than tin....(think ratshack cables)
B T W why am I hearing this from someone who's got high end Denon gear?
You didn't buy a SONY just cuz it's cool and has pretty flashy lights, you bought Denon.
MrkXCeL said:B T W why am I hearing this from someone who's got high end Denon gear?
Because Sony is weak on FEATURES, even in their ES lineup. Try reading AVSForum sometime if you can't understand that. Also, what does it have to do with this thread? I have this receiver and other than having less hiss than the Technics it replaced (which is certainly a good thing), I can't say it's noticibly better sounding. But it has way more power and way more features.
