- Aug 20, 2008
Use Windows 7 and see what kind of scores you get.
W7 ultimate 64bit RC is up on my machine!
I'll have some new scores soon. Have to figure everything out again.
Not only potentially more powerful but with less power and heat.
Apparently you missed the extreme sarcasm in my post.
Some great scores here but what is everyone getting with stock clocks on both cpu and gpu?
Curious and comparing all the scores to my sons pc not to sure if it's running as good as it can![]()
Spec is bottom one in sig and the score was 14487
Running Win7 64, 9.8 hotfix ccc, latest bios for MB all other drivers are up to date, it doesn't seem to matter if i overclock it in ccc still get the same score as standard clocks.![]()
nice scores , I must of got a crappy asus 4770 cause mine wont push past 840 / 850 when I try furmark just locks up , maybe they make a aftermarket cooler still scored 13.6k in 06
How does it game?
I've noticed in Crysis warhead that I get a bit of object flickering tree's, shrubs etc I also get the flickering in the Resident evil 4 benchtest in some of the buidings etc even with AA turned of it still does it, but it doesn't do it with my 4850![]()
Sounds like your CCC settings need to be adjusted.
what is the difference between 3Dmark Vantage and 3Dmark06
on vantage, I'm only getting 13,000 or so with a GTX260,
do most people here use 3dmark06 or vantage, and which version? like, basic, advanced..
upcoming HD4770 cross on asus P45 matx:
not a bad oc on hd4770, isn't is?
http://www.xtremesystems.org/forums/showpost.php?p=4002042&postcount=75
no not necessary....
I put some heatsink home made on the gpu mofset (they get warm when raising vgpu)
Sonda5 do you game much or do you just run benchmarks with your cards? I'm not trying to be a prick I'm just curious. It seems like all your posts are about benchmarks.
Connecting another PSU doesn't make your games run any faster. In fact, I doubt you'll see any difference since you weren't really getting near 650W of power consumption.I game as much as I can.
With the VX450 dedicated to the HD4770s I spawn almost instantly after dying in UT3.![]()
You're right, you will find out for yourself. Although any differences that you do see will be due to the placebo effect.
Adding a PSU doesn't make your computer run any faster. That is a fact. Any increase in performance that you might perceive as a result of doing so is therefore a product of your imagination. That is also a fact.
You implied it here:When did I ever say that adding a dedicated PSU for my HD4770s will make my computer run faster?![]()
I just wanted to make sure that you don't actually think the PSU is speeding things up.With the VX450 dedicated to the HD4770s I spawn almost instantly after dying in UT3.![]()
Your system may be overclocked quite a bit, but it still doesn't use all that much power. Certainly not 650W, anyway.Also to help you understand what kind of high quality power requirements my system requires let it be known my system is highly over clocked and has many fans for air cooling which I'm sure suck up some of my systems power band and effect overall quality of my power system. If after doing my testing with multi-PSU setup doesn't help my system out I'll go back to single PSU configuration.
