Syribo
- Mar 9, 2008
..Okay so maybe not bees. I'm trying to troubleshoot a problem here... I'll start off with information about my system (Most can be found in my signature
I love signatures because they make getting information to and from other members on the boards much faster!)..
I've recently been having a few things happening, and I think I have found the common point between them all.
When my external hard drive (The Seagate 7200.11 500GB SATA HDD inside the Antec MX1) is connected to my computer and I try to use Explorer or try to access anything that needs to find information from that drive, Explorer.exe freezes. It won't let me delete or copy or move any files from anywhere on the drive either. I tried to run a virus scan on just that drive, and it wouldn't get past 0% because it was 'unable to scan such and such files'.
Then my mouse begins to act eractically..Or just the cursor, rather. The cursor starts getting sluggish and it lags when moved across the screen at all. You know, it disappears and then appears over and over again. I also pretty much can't do anything else. Web surfing, gaming, communicating with people... nothing.
I'm wondering.. could this be either hardware failure or maybe a virus?? I scanned the remaining two hard drives on my computer (HDD1 has my OS HDD2 has some movies and TV shows) and they both come up clean..
I don't know what my next step could be.. Could it be a problem with the external compartment itself? Should I take out HDD1 or 2 and try to see if they work inside of the MX1, and also just set up the 'bad' drive (HDD3) as an internal drive, to see if anything changes? Or does it definitely sound like something else?
I have it turned off and not connected right now... I really want these thousands of pictures I have on it
Any insight or tips would be appreciated as usual
