nVidia basically did what I've been expecting sometime during the past few generations. Both AMD and nVidia have had high end cards with dual GPUs for a while now, so it makes total sense to just cut the card in half and use that as a single GPU solution. The much smaller PCB means it has to be quite a bit cheaper to produce than a full length card.
In fact, if you take the back half of a GTX 690 and rotate the power components 90 degrees, you'll see it's virtually identical to the 670 layout.
This a huge win for SFF fans like myself, since even small changes in card lengths can have a drastic effect on airflow inside the case. The 670 is going to be perfect in my new Shuttle.
