a single 660ti is certainly slower than a gtx470 sli and 660ti sli would be about a 45-50% upgrade from gtx470 sli.Yah BF3, GW2, Arkham City, all the good stuff.
Will a 660ti be an upgrade from 470 2xSLI or roughly the same?
no I thought he was referring to 660ti sli.You're not saying a single 660 Ti is going to be 45-50% faster than 470 SLI are you? Cause that isn't true. A single 660 Ti is 50-60% faster than a single 470, so probably about even with 470 SLI (depending on scaling, etc). Lots less power and heat though.
No offense to cannondale, I'm quoting Forceman because he's most "on the money". The 670 uses about as much power as the 470. A word about framerate: I shoot for a 60fps average. I actually mainly play older games so I can easily get something like 60 fps MIN, if not more. Not running 1080P even helps more.You're not saying a single 660 Ti is going to be 45-50% faster than 470 SLI are you? Cause that isn't true. A single 660 Ti is 50-60% faster than a single 470, so probably about even with 470 SLI (depending on scaling, etc). Lots less power and heat though.
The review someone might want to checkout for comparing the 660 to the 560 and 460, not SLI is:
http://www.hardocp.com/article/2012/08/16/galaxy_geforce_gtx_660_ti_gc_3gb_video_card_review/
Pages 4, 6, 8, 10, and 12, lower part of the page.
I'm referring to the BF 2 photo below this text. Guess I'll show the skyrim pic also.
Performance always varies by game, although faster setups are usually #1 in numerous games.
The 660 is twice as fast as a single 460 and about 50% faster than a single 560(or 470), depending on the game. I'll use the picture below for reference(well, I mean I'll calculate a couple points just using my head). A singl 660 Ti is actually really close to 470's in SLI. The 660 can OC very well and gain 5 or 6 fps depending on the game.
Average FPS: 660 = 75fps, 560 = 50fps, 460 = 37fps(ignore). 100% effective 560/470 SLI would be 100fps, 80-85% effectiveness would be 80-85fps for 470 SLI.
A single 660 gives about 90% the performance of 470 SLI.
I'd recommend a single 670 for a decent upgrade though. That, or 660's in SLI.
Although, I figure it's smarter to get a 670 then when they drop $50-100 get a 2nd for SLI. Buying a good used card can be fruitful. Depends how much $$$ someone has to begin with.
---If someone is only using a single 1080P monitor a single 660 or 670 is fine. The power usage is actually pretty close also. See 3rd pic below. Do know that the CPU is also using alot of power, it's not just the GPU. So if you CPU is lesser than a i7-3770 OC'd to 4.8 then you'll use even less power.
p.s. - In the pics below going from BF 3 to Skyrim for those settings it's interesting that the FPS of the 460 and 560 basically stay the same but the 660 drops from 75 fps to 65fps. The minimum framerate of the 660 (or 670) is still vastly superior to the 560/460/470. Remember the 660 actually beats the 580 also. Some games don't take as much advantage of SLI.
EDIT EDIT: Price update - I've heard the 670 might get down to $350 on holidays.
You can average 120 FPS sure, but it won't be in the "newest" games. That is just not very realistic. 120FPS average is for those 120 hertz monitors to work with vsync.Problem is, the guy up there wanted to average 120 fps on the newest games...I don' think any setup can handle that really...Unless you SLI 690's but that's not even worth it haha
Some games can do that with a 670 SLI for instance but a few can't. Crysis 1 and 2, Skyrim......Max Payne 3 I guess, I'm not sure.
Hey Drexel, so have a PSU with @ least 650W?
Yes, yes about that! Haha I have a Corsair TX 650M; a very good 650 watt PSU. I'm hoping it will hold up![]()
I used 300 actual watts at times with just a single oced gtx670 and 2500k at 4.4.Yeah, that's a good one. 670 SLI actually uses about as much power as a single 480 so you should be set.
670 SLI uses about 400W in reality, or ~70% of max power, which helps efficiency. Gives you room to OC or add a HDD or 2 if you wanted.
By the way that's total system power use. Some websites use high power OC'd CPUs which effect usage.
Adding another OC'd 670 to that setup I'd say the max wouldn't be any more than 450, 75% of a 600 PSU at most. Thnx for the input.I used 300 actual watts at times with just a single oced gtx670 and 2500k at 4.4.
Yes, I'd stick to the ones with 6+6 inputs. I don't think that takes much away from the overclock compared to 6+8, if you decide to.Yeah I figured I'd be alright. Do you think I should just go with stock 670s then? Rather than ones with 8+6 power inputs?
I am now debating on whether or not I want to swap it for a new GTX 680 or a pair of 660 Ti's. They'd be roughly the same price since I bought close to a $600 680. From what I could tell/hear, 660 Ti's in SLI perform up to 50% better than a single 680.
I remember reading an article - sorry, but I can't remember where - that indicated that 3x 660 gave equivalent performance to 2x 680. Personally, I'd go for the single card just to avoid any SLI glitches.
Yes, the stock blocked Gigabyte with 2 fan cooler.Alright so, now we're looking for 670s with 6+6 inputs and a little to no over clock out of the box in order to be safe on the power and to give some headroom to over clock myself. I was looking at the EVGA FTW. Any other good ones meeting the req’s?
Tri-Sli or Quad-SLI doesn't work quite as well as SLI... Tri-SLI is for Epeen Lol.
NE - http://www.newegg.com/Product/Product.aspx?Item=N82E16814125438 - $20 rebate.
Amazon - http://www.amazon.com/GIGABYTE-WIND...qid=1346601732&sr=8-1&keywords=GV-N670WF2-2GD
I know you and I like the blower fan design but the "big fan" will cool way better and be extra quiet. PS - If you don't know the new GPU's have a "boost" clock which increases the core speed ingame 60-100 Mhz by itself.
Tri-Sli or Quad-SLI doesn't work quite as well as SLI. It's all about the drivers and there are scaling issues. Not to mention Tri-Sli is only good for something like 25x16 res or higher with AA cranked to take away the CPU bottleneck. Tri-SLI 660's would cost about $900 so someone with that kind of cash would probably SLI 680's instead for about $100 extra. Unless someone didn't actually get Tri 660's all at once. Tri-SLI is for Epeen Lol.
Hmm, I've never heard about that with Tri-Sli. I know provides more FPS. Some people either can't afford Tri-Sli or don't have a mobo or PSU to support it.One thing I've consistently read is that tri-sli and tri-fire give you a smoother gaming experience as microstutter is much lessened.
Right, you had a 680. You know about the boost clock. Almost don't have to OC, but I'd want the base clock to be at least 1000Mhz, which is easy.Yep, I'm very familiar with Kepler, I had a 680! I've heard good things about the Gigabyte but I just don't really like the look of it :/
That's not too many more pixels than 5Kx1K.how is a 680 with low or no aa at 3600x1920? (3 24 inch monitors)
i was using 2 6970's previously
um how is that humorous? its actually pretty sad that a 660ti cant even beat a nearly 2 year old gtx580 across the board. if it could not beat the 570 then it would be a total failure IMO. I think some of you have just set the bar way too low for this generation of cards.
Had to work "all day".So here's my replies.
I won't recommended changing brands to another card with a blower fan. I'll link you an MSI and ASUS. They too have multiple fans similar to the Gigabyte.
If you don't like the looks of any of these 3 then I'd stick with the Evga FTW since the warranty is tried and true as far as I know.
If you have good cool airflow, the temps won't be high. It's all about good airflow with a blower fan card, or 2.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685
Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121637
http://www.amazon.com/MSI-DisplayPo...F8&qid=1346650186&sr=1-1&keywords=MSI+GTX+670
Amazon
http://www.amazon.com/ASUS-GeForce-...id=1346650235&sr=1-1&keywords=GTX670-DC2-2GD5
Slyr-
what do you think of this card?
http://www.amazon.com/EVGA-GeForce-...-P4-2670-KR/dp/B007Z3HZIA/ref=pd_sim_sbs_pc_3
It's currently $20 off on Amazon on top of the already low 379.99, so it would be 359.99 plus free one-day shipping with my Discover card! Damn, thinking about pulling the trigger; don't know how long it will last for!
Edit:
This one is also $20 off!
http://www.amazon.com/gp/product/B008HZ5438/ref=vp_c_ASQNUUYL593HQ?ie=UTF8&m=ATVPDKIKX0DER
its the FTW edition but it's the LE edition. Its slightly underclocked I believe..
For $10 more, I'd get the FTW version.
Yeah, you should be good matrix.well 5720x1200 is the same as 3600x1920, just the orientation of the monitors is different sounds like i should be good then!
Regarding the Asus TOP edition: Just DONT get it. It's OC'd too much and Asus doesn't verify the clocks well enough so numerous people have to RMA it or downclock to not crash.I've been looking at both of those as well. The MSI one looks fantastic and the Twin Frozer cooling is one of the best. The ASUS Top cards are always great, but I've heard that a lot of people are RMA'ing their cards. It seems as if the 670 version of the TOP cards are having some kind of issues so I am going to steer clear of them I think. My airflow is great in my case so I don't think having a blower-type card would be an issue..
If you like this MSI, I really would recommend it even though its $20-30 more than the Evga. For me the dual fans make up for it. Superior cooling and low noise. If it's not already OC'd up to the FTW card then it can easily match that. Instead of having the $20 coupon, the MSI says "Get "Borderlands 2" for Free with Purchase of Select GeForce GTX 6-Series Graphics Cards" - Learn more.Yeah, I'm about to press the button; but now I'm also considering the MSI Power Edition one w/ Twin Frozr 4..lol
http://www.amazon.com/gp/product/B008BGXYAS/ref=ox_sc_sfl_title_1?ie=UTF8&smid=ATVPDKIKX0DER
Once again I had to work "all day". Literally I worked from 10am to 9pm.Yeah, you should be good matrix.
If you like this MSI, I really would recommend it even though its $20-30 more than the Evga. For me the dual fans make up for it. Superior cooling and low noise. If it's not already OC'd up to the FTW card then it can easily match that. Instead of having the $20 coupon, the MSI says "Get "Borderlands 2" for Free with Purchase of Select GeForce GTX 6-Series Graphics Cards" - Learn more.![]()
Evga has good service and those aren't customs cards so the power draw isn't too high.Damn! That is awful working that much!! Hope you are rolling in the cash!
But I've been deliberating the past few hours and I think I'm gonna pick up two of the FTW cards (btw they get Borderlands 2 free as well!). I love the look, EVGA service is very reliable, overclocked out of the box to 680 speeds and since it's a reference cooler, it should (presumably) draw less power than the MSI card would; which is good for me with my 650 Watt PSUI will sleep on it I think..
Nice temps actually for that standard card.My Evga 670 ftw 2gig performs quite well plus the warranty is there. my temps are around 64-65 degrees during game play. For airflow though i have a huge tower fan supplying air instead of running the case open.
