GTX 570: $349 @ Newegg
More of a release topic if anything. Good bang for your buck considering its the same performance as a 480, draws 50W less, and is $50 bucks cheaper.
why is a card listed at it's msrp considered a hot deal?
Cause NewEgg will almost certainly jack the price up. Well, every retailer will. So launch day (if still in stock - which they seem to be) is the best to pickup for this gen so far.
It supposedly runs cooler & uses less power. maybe the extra $130 you spend upfront will save you money on your electricity bill later on?
power consumption is basically the same so I don't where you got that it uses less power from. it is faster, cooler and quieter like I said though.
What makes this $130 better than a GTX 470?
http://techreport.com/articles.x/20080/1?preview=ff668b34fde0b92aef088e9b53c61dff
From what I can tell in all these benchmarks, 470 seems about on par with the 460 1GB, and even worse in some benchmarks :confused: The difference after that, to a 480 or 570, seems huge: at least 10 fps in almost every benchmark... so considering it's cheaper than the 480 and performs better in every bench I'd say it's every penny worth $130 over the the 470.
Looking at those benches, the price difference between 460 and 470 however, does not seem worth it.
With some of the 470's sitting at $200 or less, I'm not sure it would be worth it for me.
Then again, I hit the BF deal for one at $158. If these were $300 it would be more tempting imo.
faster, cooler and quieter. the gtx470 is being phased out so that why its price is so much cheaper.
I could care less about the temps and I've ran both a reference 470 and Galaxy's GC w/ no noticeable increase in noise over some 1200 RPM Scythes...excluding furmark of course. It turns into a blow dryer w/ that.
So I guess the only draw's the extra shaders...at least from where I'm standing. Or potentially more OC headroom.
An 800Mhz 470 will run circles around a 900Mhz 460 1GB. That's based on personal experience w/ Bad Company 2 and L4D2 on a core i5 760 @ 4Ghz. I'd estimate the difference to be around 25 ~ 30 % in favor of the 470.
Should have bit on that MSI 470 for...what was it? $160 last week?
Tough to see how good a deal this is when the 6950 is due in a week. Hopefully that will start making these prices look even better
Especially since there are no reviews showing how these two compare.
I actually just stepped up today to the 470 because it was the last day in my EVGA step up, and after looking at the benches I was pretty disappointed I missed the 570, but I"m glad you find a big difference after overclocking, hopefully I will do the same
you mofos love to troll don't you
thanks op
good deal 350 for 570 = 480 but runs faster/ cooler/ efficient and cheaper
...a big difference after overclocking, hopefully I will do the same
Well, figure 607 to 800's over a 30% overclock and you'll begin to see just how big a difference it can make. Get ready for an inferno tho. No fun out here in AZ.
Since when is selling for MSRP a "hot deal"? And with 5850's for $180 and 5870's for $250, this card is a bad joke.
regarding power consumption, the 570 consumes 43W less than the 480.
Assuming you play games 2 hours a day and spend $0.10 per kWh, it will take you 31 years to recoup $100 in up front cost :p
If you run folding at home 24/7, however, it will only take you about 2.5 years to recoup your $100
Lol...love when someone comes in to explain the post above. :D
But yeah, $130 more than a 470 and 10% more performance at the same clock. Hardwarecanucks got it up to 850something on stock volts though. 950 possible? That'd probably be a 30% jump vs an 800Mhz 470.
After the $160 MSI 470 though...well, this deal blows.
if you bought an evga in the last 90 days it might be worth it to use their "step-up" program to upgrade to the 5xx series. Depending on the price differential, it could be very affordable indeed.
The post was in reply to the one directly preceding it, I think...
I thought it might be, but I didn't see how it applied...
What does he mean IF? He means IF you run folding at home... which is why he said IF you run folding at home... :confused:
Where do you see a 10% performance increase? I thought the 470 to 480 was more than 10%, and the 570 is better than the 480. These benches look like a lot more than 10%:
http://www.tomshardware.com/reviews/geforce-gtx-570-gf110-performance,2806.html
HardOCP showed more than 25% in all benches.
I'm guessing the increase in performance from a GTX 570 @ 725Mhz would be about 10% faster than a GTX 470 @ 725Mhz. I'm basing this off the 570's 20% greater core/shader clocks.
@ default clocks the margin would obviously be greater, but how many of us aren't pushing a slider to the right for free performance?
[H]'s review placed the 570 as 25% better than 470, which I found pretty surprising and hard to believe. That seemed to be at 2500x1600 resolution. I wonder what's making the real difference there, since it's got the same RAM and bandwidth. Anyone know?
e: Good explanation over at Tom's:
That is to say, the card’s GPU features 15 Shader Multiprocessors, yielding 480 CUDA cores and 60 texture units. That’s GTX 480’s bosom. It also wields five ROP partitions, a 320-bit memory bus, and 1.25 GB of GDDR5 memory. That’s GTX 470’s derriere.
And of course you end up with the architectural enhancements made to GF110. Mainly, FP16 texture filtering happens in one clock cycle, just as it does on the GF104 found in GeForce GTX 460, and not the two cycles endured by GF100. Nvidia also made improvements to GF110’s Z-culling efficiency. This means the GPU is smarter about discarding pixels that don’t need to be rendered in a scene (because they’re behind other objects), conserving memory bandwidth and compute muscle.
The good news is that the 470 and 570 are obviously not vRAM or mem bandwidth limited at 25x16, which I suspected since I was able to run 6400x1200 with 470 SLI. This gives me confidence to roll with 470 Tri SLI in near future for super low price. :)
I like where things are headed with this 570 here .... Gotta love competition. I just wish there was a third competitor these days ... *sigh*...
