So I just picked up a pair of Gigabyte Windforce GTX 1080's. Every time I try to use the displayport to power my LG34UM94 (native 3440x1440) resolution, I would not get a signal and only black screen. A few times there was "out of range" error and black screen. Switch to HDMI and it's working fine in single or SLI mode. However, HDMI is limited to 50Hz at this resolution. I tried displayport to minidisplayport and connect the minidisplayport to thunderbolt on my monitor and there is no signal. Inside NVIDIA control panel, the only connector recognized is HDMI even when the displayport is connected.
Some of the solutions I tried:
-Switch to another displayport cable = no signal.
-Switch to a different video card and use displayport = perfect signal. I used to power this monitor with GTX 980 SLI without issues.
-Updated to latest nvidia driver (372.54) as of this moment = no signal from displayport.
-Update windows to latest patch, etc = no signal from displayport.
Of note, I have the same issue with a founder edition GTX 1080 prior to this. I checked Nvidia forum and seems like the displayport will work for some and not others. No consensus on solutions.
Does any forum member have a solution or suggestion for this problem? Thanks in advance.
Spec:
-CPU: Intel Core i5 2500k OC'ed to 4.6 Ghz
-Motherboard: Asus P8P67 Pro
-16GB of ram
-Sound card: Asus Xonar DX
-PSU: Corsair 1200W
-GPU: Gigabyte GTX 1080's in SLI
-Monitor: LG34UM94.
Spec:
-16GB of ram
-PSU: Corsair 1200W
-Monitor: LG34UM94.
