horrorshow
Lakewood Original
- Dec 14, 2007
Glad to hear this game is finally getting the full attention of the [H] community!!
Enjoy fellas!
Enjoy fellas!
You unlock the higher difficulties by completing the campaign of the lower difficulties, works pretty much the same way as in Diablo 2 and Diablo 3 Vanilla, where if you want to access Nightmare, you have complete normal, and if you want to access Hell, you have to complete Nightmare, etc.
Veteran is an exception, it's a slightly more difficult version of Normal where all oranged named 'Champions' spawn in pairs. This is only accessible in Normal.
Also, as side effect, you can actually complete quests in different ways between difficulties (such as choosing to help the Apprentice or the Master).
I am not actually sure how factions work in that regard though, but I plan on playing a secondary character for the two factions I pissed off.
This has been quite enjoyable so far, but i'm only about 4 hours in. I just found out last night that if you combine some of these fragments you find everwhere, some of them give you moves!
Are these something that people build around? or is it just for low levels?
Dreeg's Infinite Gaze skill you get from the Mark of Dreeg's component is def. a skill you can build around if you're going for a poison/acid build. I use it with my witch hunter and it shreads mobs pretty good, you just need to be surrounded for it to be effective. That with Evil Eye Bombs, Sigil and Blood of Dreeg for the adcth and regen makes a great combo.This has been quite enjoyable so far, but i'm only about 4 hours in. I just found out last night that if you combine some of these fragments you find everwhere, some of them give you moves!
finished the game finally I'm level 39 I know I can Grind till 50 to get good gear but I'm done. Final Boss was a hoot died about 12 times
The shrine gives Devotion points, which is accessed via the Devotion tab in the Skills screen.You can add them to weapons and armor any time I don't know how the shrine thing works I only cleansed one of them and some stuff spawned out and gave me some loot.
Then a skill Tree pops up with extra abilities. I'm in the last area of the game not sure if I should finish it or wait for DLC...
I know that the components remain useful throughout the game (the dropped ones are often used to create the rarer ones), so it's best to start collecting early.This has been quite enjoyable so far, but i'm only about 4 hours in. I just found out last night that if you combine some of these fragments you find everwhere, some of them give you moves!
Grim Dawn isn't ideal, since you can't refund mastery nor stat points
This is why I also hate games where a respec costs a week full of grinding.
As have mine! My taste in games it seems is always changing with time. I cannot believe how many times I'd restart a new character in D2 or WoW back in the day for messing something up. Guess it was just cause I had more time... but yes. I spent a couple points in spirit on my battlemage before i realized in order to hit people i really needed to be pumping cunning. So, I can completely sympathsize with you over wanting to not waste time in gaming any longer with restarting for the sake of a couple stat points. However, D3 just took it too far the other way where I never felt i was actually building a character. Grim dawn, for me, has been the perfect mix. Easy respeccing (it's still really really cheap and i've been able to try moves and out remove the points if i don't like it) and cool skill trees.Actually my taste in ARPG in general have changed since my younger days.
Gone are the days where I would try new things out, and build new characters just for a couple of stat points.
In are my attitude that I want to build the perfectly statted from the start. That's why I don't have issues with D3's skill system, I can try stuff without penalties. I no longer have the time nor the patience to level up another entire character just to see if one passive would work or not.
Just like in real life, I am terrible at starting/learning things from scratch, and I usually end up with stuff that doesn't work, but give me a starting build, and I can work my way into the build and change it to suit my style.
Grim Dawn isn't ideal, since you can't refund mastery nor stat points (the latter made my Conjurer non-ideal, because I already put 18 points into Cunning, hopefully it is not crippling), but at least devotion and skill points are cheaply refundable.
Awesome!!!!!!!!!You can use this to reset mastery/stat points: Cheat Engine :: View topic - [v5.99] Grim.Dawn.v1.0.0.4.PLUS.104.Trainer
Much appreciated.
Used it, thinking about uninstalling it now, I want to use it as sparingly as possible. I don't even want to use it as a way to respec, let alone to cheat with lol.
