GPU client running, should I turn off CPU client?
wurmy
My apologies, it's probably been asked before, but I'm recovering from injuries and have just started folding with a ATI 2600, and a dual-core AMD.
In general, do I get better results running both, or just the GPU client?
Thanks in advance for replies!
Run the GPU, and run a standard single client, and you will be fine.
Hope all goes well with the recovery, and don't worry on the questions. That is why we are here.
Fold on, fold [H]ard!
PS, make sure the vid card will finish the WU by the pref deadline. You might be right on the line with that card.
Yeah, I suggest you do as Kendrak says. On a dual-core AMD CPU, you probably don't have enough CPU grunt to handle an SMP client and a GPU client, so you'd be best off sticking to a uniprocessor client on one core and the GPU client set to the other core. You should also consider locking each of the clients to a specific core to maximise your performance (the instructions should be in one of the guides).
