GPU Benchmarking - Crysis 1280x1024 (All High)
redman223
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 46.78s, Average FPS: 42.75
Min FPS: 25.71 at frame 162, Max FPS: 52.59 at frame 985
Average Tri/Sec: 43240748, Tri/Frame: 1011485
Recorded/Played Tris ratio: 0.91
!TimeDemo Run 1 Finished.
Play Time: 43.48s, Average FPS: 46.00
Average Tri/Sec: 46984532, Tri/Frame: 1021365
Recorded/Played Tris ratio: 0.90
!TimeDemo Run 2 Finished.
Play Time: 43.52s, Average FPS: 45.96
Min FPS: 25.71 at frame 162, Max FPS: 53.54 at frame 1023
Average Tri/Sec: 46990092, Tri/Frame: 1022481
!TimeDemo Run 3 Finished.
Play Time: 43.42s, Average FPS: 46.06
Min FPS: 25.71 at frame 162, Max FPS: 55.09 at frame 1015
Average Tri/Sec: 47047984, Tri/Frame: 1021392
TimeDemo Play Ended, (4 Runs Performed)
Me again! I just reformatted my HDD and installed a 64-bit version of Vista. Here are my results:
Play Time: 50.92s, Average FPS: 39.28
Min FPS: 29.77 at frame 1959, Max FPS: 50.42 at frame 1004
Average Tri/Sec: 38391120, Tri/Frame: 977348
Recorded/Played Tris ratio: 0.94
Play Time: 48.05s, Average FPS: 41.62
Min FPS: 29.77 at frame 1959, Max FPS: 52.79 at frame 95
Average Tri/Sec: 41013468, Tri/Frame: 985406
Recorded/Played Tris ratio: 0.93
Play Time: 48.06s, Average FPS: 41.61
Average Tri/Sec: 41039296, Tri/Frame: 986183
Play Time: 48.04s, Average FPS: 41.63
Min FPS: 29.76 at frame 1959, Max FPS: 52.79 at frame 95
Average Tri/Sec: 41019092, Tri/Frame: 985257
I knew something wasn't right before. Anyway, I still need to do some more testing. As soon as the OS was installed, I installed the 169.04 beta drivers and the demo, set the resolution and settings in-game then ran the benchmark. There's still a whole load of other drivers I need to install, like those for my wireless network adapter.
Because I wasn't connected to the internet when I installed the demo, I couldn't install the update it prompted me to install. Can someone provide a link to this particular update, because I'm interested if it'll improve performance any more? Thank you.
Nembot
E6600@3.0ghz, 4gig mem, 8800gts640 169.04
I see similar fps drops with the renamed exe in XP also...
============================================================== Vista 64bit crysis.exe (reflection problems)
Play Time: 55.36s, Average FPS: 36.13
Min FPS: 25.83 at frame 1962, Max FPS: 52.49 at frame 102
Average Tri/Sec: 35385016, Tri/Frame: 979374
Play Time: 52.21s, Average FPS: 38.31
Min FPS: 25.83 at frame 1962, Max FPS: 60.10 at frame 112
Average Tri/Sec: 37843052, Tri/Frame: 987806
Play Time: 52.26s, Average FPS: 38.27
Min FPS: 25.42 at frame 1944, Max FPS: 60.10 at frame 112
Average Tri/Sec: 37791744, Tri/Frame: 987574
Play Time: 52.15s, Average FPS: 38.35
Min FPS: 25.04 at frame 1955, Max FPS: 60.50 at frame 76
Average Tri/Sec: 37852232, Tri/Frame: 986970
============================================================== Vista 64bit renamed exe (reflections working)
Play Time: 59.16s, Average FPS: 33.81
Min FPS: 21.54 at frame 146, Max FPS: 43.36 at frame 1202
Average Tri/Sec: 34401356, Tri/Frame: 1017629
Play Time: 55.49s, Average FPS: 36.04
Min FPS: 21.54 at frame 146, Max FPS: 47.12 at frame 99
Average Tri/Sec: 37136564, Tri/Frame: 1030440
Recorded/Played Tris ratio: 0.89
Play Time: 55.80s, Average FPS: 35.84
Average Tri/Sec: 36940032, Tri/Frame: 1030592
Play Time: 55.58s, Average FPS: 35.99
Average Tri/Sec: 37029520, Tri/Frame: 1028959
Theopolis
leadtek 8800gt stock
can anyone suggest #s on a modest overclock?
Play Time: 67.66s, Average FPS: 29.56
Min FPS: 21.25 at frame 1965, Max FPS: 40.00 at frame 990
Average Tri/Sec: -30301510, Tri/Frame: -1025145
Recorded/Played Tris ratio: -0.89
Play Time: 64.92s, Average FPS: 30.81
Min FPS: 21.25 at frame 1965, Max FPS: 40.11 at frame 992
Average Tri/Sec: -31301360, Tri/Frame: -1016109
Recorded/Played Tris ratio: -0.90
Play Time: 64.70s, Average FPS: 30.91
Min FPS: 21.25 at frame 1965, Max FPS: 40.45 at frame 63
Average Tri/Sec: -31396346, Tri/Frame: -1015627
Play Time: 64.68s, Average FPS: 30.92
Min FPS: 21.25 at frame 1965, Max FPS: 40.58 at frame 65
Average Tri/Sec: -31413774, Tri/Frame: -1015928
Post OC below... 699/1699/949....Best stability for me so far! And a nice jump in frames...
Play Time: 55.68s, Average FPS: 35.92
Min FPS: 23.90 at frame 158, Max FPS: 46.76 at frame 993
Average Tri/Sec: 35111028, Tri/Frame: 977558
Play Time: 52.09s, Average FPS: 38.40
Min FPS: 23.90 at frame 158, Max FPS: 47.65 at frame 93
Average Tri/Sec: 37796284, Tri/Frame: 984389
Play Time: 52.14s, Average FPS: 38.36
Min FPS: 23.90 at frame 158, Max FPS: 48.17 at frame 108
Average Tri/Sec: 37797300, Tri/Frame: 985290
Play Time: 52.08s, Average FPS: 38.41
Min FPS: 23.90 at frame 158, Max FPS: 48.46 at frame 72
Average Tri/Sec: 37840116, Tri/Frame: 985279
astrojunke
Yep, definitely ran it at 1280x1024. At 1680x1050 I get around 24-26FPS off the top of my head. I really don't know what's wrong with my computer. :confused:
are you sure all the settings in the nvidia control panel are at the best perfomance settings?
Viperlover
Holy shit! The highest I can get mine up to is 660/1010!
plac
My system specs are in my siggy.
Current driver 169.04
Play Time: 59.13s, Average FPS: 33.82
Min FPS: 18.16 at frame 139, Max FPS: 54.95 at frame 1001
Average Tri/Sec: -32058754, Tri/Frame: -947828
Recorded/Played Tris ratio: -0.97
Atech
System in rig, all stock setings, 169.02 WHQL:
Play Time: 55.77s, Average FPS: 35.86
Min FPS: 22.67 at frame 138, Max FPS: 46.05 at frame 986
Average Tri/Sec: 36304432, Tri/Frame: 1012402
Play Time: 50.84s, Average FPS: 39.34
Min FPS: 22.67 at frame 138, Max FPS: 46.71 at frame 996
Average Tri/Sec: 40217924, Tri/Frame: 1022301
Play Time: 50.81s, Average FPS: 39.36
Average Tri/Sec: 40270784, Tri/Frame: 1023123
Play Time: 50.80s, Average FPS: 39.37
Min FPS: 22.67 at frame 138, Max FPS: 47.26 at frame 1015
Average Tri/Sec: 40240756, Tri/Frame: 1022136
Yeah. Well, I tried various drivers and I assume each time the settings in the control panel reverted back to default. However, if you look at my post a few posts up you can see I'm now getting around 40FPS.
SPARTAN VI
This thread is saturated with G92 and G80s. This isn't in the nvidia forum, could we get a couple HD2900s in here? :confused:
josh_1413
C2D @ 3Ghz - 8800GTS@625/1000 - 2GB Corsair XMS
1440x900
With DX10 "features" manually enabled. Windows XP Pro
Play Time: 67.26s, Average FPS: 29.74
Min FPS: 18.63 at frame 156, Max FPS: 38.26 at frame 72
Average Tri/Sec: -29106690, Tri/Frame: -978833
Recorded/Played Tris ratio: -0.94
Play Time: 62.43s, Average FPS: 32.03
Min FPS: 18.63 at frame 156, Max FPS: 41.88 at frame 79
Average Tri/Sec: -31012022, Tri/Frame: -968078
Recorded/Played Tris ratio: -0.95
Play Time: 62.62s, Average FPS: 31.94
Average Tri/Sec: -30898780, Tri/Frame: -967370
Play Time: 62.43s, Average FPS: 32.04
Average Tri/Sec: -30993326, Tri/Frame: -967416
chrisewaters
Specs in sig, 169.04 Crysis driver.
Play Time: 213.47s, Average FPS: 9.37
Min FPS: 0.00 at frame 137, Max FPS: 13.63 at frame 1008
Average Tri/Sec: 9482397, Tri/Frame: 1012090
Play Time: 189.90s, Average FPS: 10.53
Average Tri/Sec: 10762914, Tri/Frame: 1021943
Play Time: 194.01s, Average FPS: 10.31
Average Tri/Sec: 10544567, Tri/Frame: 1022879
Play Time: 193.70s, Average FPS: 10.33
Average Tri/Sec: 10555533, Tri/Frame: 1022278
What iactualy run it on. All medium with Physics and sound on high. Best graphics ive ever seen and i can live with the framerate seeing my pc is 2 years old. Min fps only kicks in for a secound in areas were loading mostly sits around 22-25.
Play Time: 116.63s, Average FPS: 17.15
Min FPS: 8.70 at frame 145, Max FPS: 27.85 at frame 115
Average Tri/Sec: 13322591, Tri/Frame: 776928
Recorded/Played Tris ratio: 1.18
Play Time: 94.92s, Average FPS: 21.07
Min FPS: 8.70 at frame 145, Max FPS: 28.97 at frame 70
Average Tri/Sec: 16528961, Tri/Frame: 784483
Recorded/Played Tris ratio: 1.17
Play Time: 94.89s, Average FPS: 21.08
Min FPS: 8.70 at frame 145, Max FPS: 29.99 at frame 110
Average Tri/Sec: 16548593, Tri/Frame: 785111
Play Time: 95.08s, Average FPS: 21.03
Average Tri/Sec: 16522648, Tri/Frame: 785511
strend
Play Time: 66.84s, Average FPS: 29.92 Min FPS: 8.82 at frame 140, Max FPS: 44.93 at frame 975
Average Tri/Sec: -29651928, Tri/Frame: -990911
Recorded/Played Tris ratio: -0.93
Play Time: 59.70s, Average FPS: 33.50
Min FPS: 8.82 at frame 140, Max FPS: 46.97 at frame 999
Average Tri/Sec: -32828954, Tri/Frame: -979904
Play Time: 59.58s, Average FPS: 33.57 Min FPS: 8.82 at frame 140, Max FPS: 46.97 at frame 999
Average Tri/Sec: -32865004, Tri/Frame: -979116
Play Time: 59.54s, Average FPS: 33.59
Average Tri/Sec: -32911800, Tri/Frame: -979702
8800GTS 320.
3800 X2 @2.7 (s939)
2GB DDR 400
This card really can't handle HIGH textures in Crysis. Afew spots really kill performance. Look at the "Min FPS", I dont get that dip with medium textures.
shurcooL
Ok, here's what I got.
Q6600 @ 3.2 GHz
GA-P35-DS3L
2 GB Corsair DDR2-800 PC6400C4 @ 400 MHz
EVGA NVIDIA 8800GTX @ Stock
Windows XP Professional SP2 x86 (32 bits)
NVIDIA 169.04 (Beta) drivers
1280x1024, All High in game, Performance in Control Panel (0x AA, 0x AF).
Play Time: 52.85s, Average FPS: 37.84
Min FPS: 20.97 at frame 146, Max FPS: 46.68 at frame 1002
Average Tri/Sec: 38293700, Tri/Frame: 1011942
Play Time: 49.43s, Average FPS: 40.46
Min FPS: 20.97 at frame 146, Max FPS: 48.58 at frame 1008
Average Tri/Sec: 41372924, Tri/Frame: 1022483
Play Time: 49.43s, Average FPS: 40.47
Average Tri/Sec: 41388728, Tri/Frame: 1022825
Play Time: 49.40s, Average FPS: 40.49
Average Tri/Sec: 41364724, Tri/Frame: 1021616
Slade
looks like I'm in line with others on this
Play Time: 52.47s, Average FPS: 38.11
Min FPS: 28.53 at frame 1957, Max FPS: 50.04 at frame 1020
Average Tri/Sec: -38686060, Tri/Frame: -1015023
Play Time: 49.40s, Average FPS: 40.48
Min FPS: 28.53 at frame 1957, Max FPS: 53.21 at frame 88
Average Tri/Sec: -40701936, Tri/Frame: -1005379
Recorded/Played Tris ratio: -0.91
Play Time: 49.38s, Average FPS: 40.50
Min FPS: 28.22 at frame 1963, Max FPS: 53.21 at frame 88
Average Tri/Sec: -40693840, Tri/Frame: -1004670
Play Time: 49.37s, Average FPS: 40.51
Min FPS: 28.14 at frame 1964, Max FPS: 53.21 at frame 88
Average Tri/Sec: -40736472, Tri/Frame: -1005504
Betrayer00GT
8800GTS 320.
3800 X2 @2.7 (s939)
2GB DDR 400
Well, with the same setup as my benchmarking post from earlier, my single 640 does 21min/29ave/37max with "Very High" textures in the "GPU" looping benchmark, and that is with 1280X1024 & 4xAA.
Well, actually, with that run through a few things were at "very high", even with 4xAA. I ran shadows @ Medium, though. I used these settings for the run results I just mentioned, but these are the settings I play at, too:
1280X1024
AA: 4X
Texture Quality: Very High
Objects Quality: Very High
Shadow Quality: Medium
Physics Quality: Very High
Shader Quality: High
Volumetric Effects Quality: Very High
Gave Effects Quality: High
Post Processing Quality: High
Particles Quality: Very High
Water Quality: High
Sound Quality: High
Again, for 21min/29ave/37max. I am happy, the demo is beautiful and fun to (re)play. Can't wait to grab a retail copy. :D
Betrayer00GT
That is the one I got in September, the one I got in March would only do 675/1566/999. I do not know what revision the March one is ATM, but the one you quote there is an A3. Also, that tool is not horribly accurate, as the real numbers are 684/1620/1080. It is real close, though. And that tool does the math on mem bandwidth and fillrate and such.
A little off-topic, but does anyone have any 2GB vs 4GB memory comparisons for the Crysis Demo benchmarks? Also, does anyone have the URL for the update that you're prompted to download and install after just after the demo finishes installing?
shurcooL
What update? I never got that.
WasntMe
My friend has the same PC as me, except he has 4GB of memory compared to my 2GB. We didn't see a difference is Crysis or 3dmark06 for that matter.
Oh right. That's a bit annoying seeing as I just ordered another 2GB. Oh well, it was cheap. Thank you, nevertheless.
theNoid
Seems GT (GTX) and Quad cores with 2+ GB of RAM are performing nicely. I'm looking to perform a 'complete' overhaul this month and I now know what I need.
Jooky
Windows XP SP2
Nvidia 169.04
Rig running all stock settings.
Play Time: 54.69s, Average FPS: 36.57
Min FPS: 20.09 at frame 138, Max FPS: 45.52 at frame 972
Average Tri/Sec: 36997860, Tri/Frame: 1011702
Play Time: 49.54s, Average FPS: 40.37
Min FPS: 20.09 at frame 138, Max FPS: 48.04 at frame 993
Average Tri/Sec: 41232260, Tri/Frame: 1021401
Play Time: 49.52s, Average FPS: 40.38
Average Tri/Sec: 41277668, Tri/Frame: 1022131
Play Time: 49.52s, Average FPS: 40.39
Min FPS: 20.09 at frame 138, Max FPS: 48.12 at frame 991
Average Tri/Sec: 41236768, Tri/Frame: 1021076
WasntMe
Yeah we both ordered our shit at the same time while talking over TeamSpeak. After we get all the stuff ordered, he informs me, "Oh yeah I got 4GB RAM... I am better than you!" After testing, I LOLed a lot considering it made no difference at all in the games we saw.
I was going to buy some more RAM after he told me, but the test results put a halt to that pretty quickly.
Vengeance
Play Time: 60.19s, Average FPS: 33.23
Min FPS: 24.05 at frame 1945, Max FPS: 36.56 at frame 177
Average Tri/Sec: 32494814, Tri/Frame: 977939
Play Time: 58.44s, Average FPS: 34.22
Min FPS: 24.04 at frame 1963, Max FPS: 36.56 at frame 177
Average Tri/Sec: 33711468, Tri/Frame: 985017
Play Time: 58.36s, Average FPS: 34.27
Average Tri/Sec: 33780828, Tri/Frame: 985788
Play Time: 58.34s, Average FPS: 34.28
Average Tri/Sec: 33774796, Tri/Frame: 985225
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 47.89s, Average FPS: 31.32
Min FPS: 21.77 at frame 1101, Max FPS: 45.31 at frame 83
Average Tri/Sec: 32377828, Tri/Frame: 1033706
Recorded/Played Tris ratio: 0.70
Play Time: 45.12s, Average FPS: 33.25
Average Tri/Sec: 34252912, Tri/Frame: 1030231
Play Time: 44.77s, Average FPS: 33.50
Average Tri/Sec: 34439852, Tri/Frame: 1027924
Play Time: 45.14s, Average FPS: 33.23
Min FPS: 20.10 at frame 1083, Max FPS: 45.31 at frame 83
Average Tri/Sec: 34102844, Tri/Frame: 1026377
I haven't finished reading all two pages in this thread, but I am definitly in the same boat here. Anyone figure out why our GTX's are performing so poorly on this bench?? See my sig for system specs.
Play Time: 61.33s, Average FPS: 32.61
Min FPS: 23.63 at frame 1964, Max FPS: 39.37 at frame 342
Average Tri/Sec: 32963496, Tri/Frame: 1010780
Play Time: 58.89s, Average FPS: 33.96
Min FPS: 21.88 at frame 1913, Max FPS: 39.37 at frame 342
Average Tri/Sec: 34677592, Tri/Frame: 1021152
Play Time: 58.91s, Average FPS: 33.95
Min FPS: 20.48 at frame 1955, Max FPS: 39.48 at frame 350
Average Tri/Sec: 34704404, Tri/Frame: 1022255
Play Time: 59.01s, Average FPS: 33.90
Min FPS: 19.56 at frame 1950, Max FPS: 39.75 at frame 337
Average Tri/Sec: 34608380, Tri/Frame: 1021045
I am Using Vista Business 46-Bit
and the 163.69 Nvidia Driver.
I'm gonna try finding the Nvidia 169.04 driver, but I don't see how it will make up that much.
-V
Vengeance
....errrr... nevermind...
169.04 Drivers...
Play Time: 51.63s, Average FPS: 38.74
Min FPS: 29.89 at frame 1976, Max FPS: 50.11 at frame 994
Average Tri/Sec: 37850312, Tri/Frame: 977012
Play Time: 48.54s, Average FPS: 41.20
Min FPS: 29.79 at frame 1971, Max FPS: 52.20 at frame 69
Average Tri/Sec: 40579760, Tri/Frame: 984937
Play Time: 48.52s, Average FPS: 41.22
Min FPS: 29.62 at frame 1967, Max FPS: 52.81 at frame 61
Average Tri/Sec: 40615512, Tri/Frame: 985288
Play Time: 48.51s, Average FPS: 41.23
Min FPS: 29.43 at frame 1963, Max FPS: 52.81 at frame 61
Average Tri/Sec: 40600076, Tri/Frame: 984796
Insert the part where I feel really stupid... :eek:
-V
redman223
I got an average of 46fps and I dont know why mine was so high. Your computer should be faster than mine, since you have a quad core and 4gb of ram, as opposed to my dual core and 2gb of ram.
Maybe its because of the overclock on my 8800gtx. Overclock it a bit and run the test again since this game pushes gpus to the limits, maybe it has huge benefits from a higher clock speed.
Atech
I am Using Vista Business 64-Bit
-V
That is why, try benching under XP.
Vengeance
I'll take your advise, I'm gonna try OC'ing a lil and see what it gets me. I have to admit, I was really surprised the drivers alone netted me 7-8 FPS. I know there is a bug with the reflections, so I renamed the exe.
Question, what should I try overclocking to?
I came from a ATI 1950PRO and I was using ATI Tray Tool, so I'm not sure how to OC, and test stability. It was nice that Tray Tool had it all built in.
Unfortunately I don't have a copy of XP around right now. I might go swipe it off my father sometime this weekend, and see what it can do for me.
Thanks for the help guys,
-V
Vengeance, the performance you're getting is almost identical to mine after I re-installed Vista:
Despite your quad core and 4GB of RAM, I think your benchmark results look about right. I mean, the demo barely utilises any more than a single core, and I doubt it's going to be using anywhere near 2GB of RAM, let alone 4GB, so I wouldn't worry.
What I find interesting is the minimum FPS we are getting on the GPU benchmark. It seems to be a lot higher than other peoples who have similar average FPS. At least that's something to be pleased about, huh?
Vengeance
I think you're totally right Tissue.
But I found something really interesting just now, sadly I have to get into my office so I don't have time to post about it. I will however post up from my office, so give me about an hour, and I should be able to shed some light on this.
-V
-V
Nice, I'm eager to hear your findings.
Also, I just realised how similar our rigs are. Similar memory, speakers (I have the Z-5500s, too), graphics card, power supply... So it's no surprise they perform similarly on the benchmark. Although, I'm guessing your rig will really shine in the full game which will probably make use of your quad core and extra memory. I have another 2GB of Ballistix on order (I'm using 64-bit Vista as well!) and I'll be running the benchmarks again if anyone's interested in a 2GB vs. 4GB comparison. Although, it won't be for a few more days because the memory hasn't even arrived yet. I really doubt it'll make much difference in the demo though which is, what, only 1.7GB ish anyway.
Vengeance
Ok, so I've finally got time to sit back and write this all out. Sorry it took so long, I got back to my office, and all hell broke loose on me....
First off, it appears there are many, many variables to consider here when running this bench mark across the various rigs here.
Just a few:
WinXP | Win Vista
32-Bit | 64-Bit
Nvidia Driver Version
Did you rename the .exe and the target in the GPU_Benchmark (To fix Nvidia's Reflection Bug)?
I don't think I'm saying anything new here, most of us know these problems. I'm saying maybe we should start addressing these when we post the benchmark results, which most posts have been doing.
Anyway, on with what I've found....
All of these Bench Results are on my system running Vista Business 64-Bit & Nvidia 169.04 Beta Drivers.
First I wanted to look at the difference between the "buggy/Cheat" versions of the 169.04 driver.
Again nothing new, most of us knew about this...
169.04 Driver .EXE NOT RENAMED Clocks @ Stock Speed
1280x1024
Graphics: All High
No AA/AF
Nvidia 169.04 Beta
169.04 Driver .EXE RENAMED Clocks @ Stock Speed
Play Time: 54.80s, Average FPS: 36.50
Min FPS: 28.31 at frame 1952, Max FPS: 41.71 at frame 337
Average Tri/Sec: 36863784, Tri/Frame: 1010075
Play Time: 52.38s, Average FPS: 38.18
Min FPS: 28.31 at frame 1952, Max FPS: 42.12 at frame 1007
Average Tri/Sec: 38991840, Tri/Frame: 1021232
Min FPS: 28.31 at frame 1952, Max FPS: 42.17 at frame 343
Average Tri/Sec: 39022880, Tri/Frame: 1022042
Average Tri/Sec: 39001312, Tri/Frame: 1021536
1280x1024
Graphics: All High
No AA/AF
Nvidia 169.04 Beta
Renamed / Fixed Reflections
The Second set of test shows how well my GTX did with a mild OC. I say Mild, because I only took about 5 min to OC. I basically guessed about 12-17MHz above some OC's I saw in peoples sigs here because I am water cooling. I think I still have some head room to go higher, I will try it later tonight when I get home.
169.04 Driver .EXE NOT RENAMED Clocks @ 662 | 1584 | 1044
Play Time: 48.24s, Average FPS: 41.46
Min FPS: 30.96 at frame 1960, Max FPS: 53.23 at frame 1007
Average Tri/Sec: 40502320, Tri/Frame: 976852
Play Time: 45.98s, Average FPS: 43.50
Min FPS: 30.96 at frame 1960, Max FPS: 54.76 at frame 103
Average Tri/Sec: 42828412, Tri/Frame: 984665
Play Time: 45.94s, Average FPS: 43.53
Min FPS: 30.96 at frame 1960, Max FPS: 55.34 at frame 72
Average Tri/Sec: 42886060, Tri/Frame: 985197
Play Time: 45.95s, Average FPS: 43.53
Average Tri/Sec: 42864044, Tri/Frame: 984715
1280x1024
Graphics: All High
No AA/AF
Nvidia 169.04 Beta
DID NOT Renamed / Fixed Reflections
OC: 662 | 1584 | 1044
169.04 Driver .EXE RENAMED Clocks @ 662 | 1584 | 1044
Play Time: 51.81s, Average FPS: 38.60
Min FPS: 31.11 at frame 1946, Max FPS: 44.20 at frame 355
Average Tri/Sec: 39012428, Tri/Frame: 1010631
Play Time: 49.32s, Average FPS: 40.55
Min FPS: 30.20 at frame 1951, Max FPS: 44.49 at frame 356
Average Tri/Sec: 41421008, Tri/Frame: 1021446
Play Time: 49.34s, Average FPS: 40.54
Min FPS: 30.20 at frame 1951, Max FPS: 45.04 at frame 992
Average Tri/Sec: 41449848, Tri/Frame: 1022470
Play Time: 49.30s, Average FPS: 40.57
Min FPS: 30.20 at frame 1951, Max FPS: 45.38 at frame 998
Average Tri/Sec: 41398452, Tri/Frame: 1020507
1280x1024
Graphics: All High
No AA/AF
Nvidia 169.04 Beta
In all I'm pretty happy with how my GTX is performing, knowing I still have some headroom to OC, and possibly squeeze out 1-3 more Average FPS. As I said before I totally agree with Tissue, that our numbers are almost identical, therefore I don't feel my GTX is underperforming.
I guess the main thing I'm pointing out, is we should note in our posts if we are running the "bugged" or "Fixed" version of the benches with the 169.04 drivers. Obviously it can make a dramatic impact on the numbers.
Credit goes to Nembot, it was his post that made me try this.
Anyway, I hope sheds a little light on things for some.
-V
Vengeance
I still don't understand how you got these numbers!
He's using Xp, I believe, which gives a very nice performance boost.
Thank you for posting your findings (and thanks to Nembot, too), I found them very helpful. I had no idea about the renaming of the .exe thing before now. I'll have to try this. What does it do exactly? I don't really know what to look out for.
pandora's box
Play Time: 54.12s, Average FPS: 36.95
Min FPS: 26.03 at frame 145, Max FPS: 44.18 at frame 1016
Average Tri/Sec: 37392052, Tri/Frame: 1011862
Play Time: 51.66s, Average FPS: 38.72
Min FPS: 26.03 at frame 145, Max FPS: 45.88 at frame 1012
Average Tri/Sec: 39545080, Tri/Frame: 1021387
Play Time: 51.65s, Average FPS: 38.72
Min FPS: 26.03 at frame 145, Max FPS: 46.47 at frame 1008
Average Tri/Sec: 39581172, Tri/Frame: 1022123
Play Time: 51.64s, Average FPS: 38.73
Min FPS: 26.03 at frame 145, Max FPS: 46.56 at frame 1003
Average Tri/Sec: 39557428, Tri/Frame: 1021319
specs in sig. card @ stock
Vengeance
Hmmm... Sucks about the XP thing, because I'm definitely on to Vista for good. I'm hooked.
As for the driver thing...
Nvidia seems to have "cheated" when it comes to the water reflections on the new drivers.
The best way to see what I'm talking about is if you look at the water during the bench right when the view starts panning back around to where the first base camp was, (The one with the radar jammer). Look at the mountains reflecting in the water. If you didn't do the fix, they will run VERY choppy as you move.
If you apply the fix, you will notice the opposite, very smooth & clear reflections. Of course this will cost FPS, but we're going for quality, not quantity here right?
Now... How to fix:
I assume you are running Vista-64
1.) Go into your Crysis Dir, forgive me, I install on a different drive path, so I don't have the full default file path.
You eventually want to get to \Crysis SP Demo\Bin64
If you're running 64-Bit go into Bin64
If you're running 32-Bit go into Bin32 <--- I&#8217;m not sure if this problem exists in 32-Bit, as I'm not running it... Maybe someone could verify??
2.) Rename your Crysis.exe (I named mine Crysis1)
3.) Right click on Benchmark_GPU and select edit
4.) On the 3rd line from the bottom, (@crysis.exe -DEVMODE +map island +exec benchmark_gpu)
Change crysis.exe to the new name from step 2.
Save and exit.
5.) Run the bench, check it out!
You can always undo the change, just rename back to the originals.
Let me know what you come up with, I'd love to compare results, since we basically have the same system! ;)
ReVRiN
They all sold their ati's and bought nvidia's. :)
Sad but true... I'm one of them... this eVGA 8800GT 650 o/c right out of the box is smoking...I cannot wait for my 3rd party cooler to arrive and then I will post my results.
