So Danny the GTX 460 is not supported by default. Hmm.
I'm reading it. Thank you for the link. So my PSU is fine right, Its Corsair 550VX
I dont need to upgrade it correct?
Not all I7's use triple channel memory only socket 1366 ones do he could have a 1156 I7 which is only dual channel.
Great.Thanks! I may grab 1 kit to get a total of 8GB.
I guess 12 GB is too much for what I do.
I guess dual channel will work fine.
Nice choice, but for After Effects, you can never have enough. After Effects CS3 ate up 5.5GB of memory, and that was in 2008 when I used it. I'm sure CS5 will need far more than that. More = better!![]()
Thanks. I might get this.
G.Skill Ripjaws F3-10666CL9T-12GBRL 3 x 4GB DDR3 1333 RAM
Is this a good brand?
