This card is priced $954.80 here at my local store, Australian prices. A standard 7970 costs like $699, talk about expensive.
Gigabyte non-reference 7970 on Newegg
Zarathustra[H];1038314543 said:Well, to be clear, I believe this and all other "non-reference" boards out there right now all use the reference board design, just with a custom cooler.
I really dont understand the hoopla over these non standard coolers. They exhaust heat into your case, which in the long run means it will run *hotter* than the reference design. Especially when put into a crossfire configuration. These are bad designs priced higher than good designs.
Very tempted but don't think one will be good enough for 2560x1600.
dcii is due soon apparently
http://www.youtube.com/watch?v=1ypFzdILgCw
Zarathustra[H];1038315117 said:Test data seems to suggest otherwise.
Provided you have good airflow in your case so that the hot air is exhausted they cool better.
If the airflow in your case is poor, then yes, the results with a cooler like this won't help.
Beautiful...
But I'm still holding out for the rumored 1300+ factory OC cards.
idk man, if hes saying that monster dcii card might go up to 1200 then 1300 might be about as much as youre gonna get OCing one of these under water. i really doubt youll see a factory OC that high. i think 1100 or 1150 might be about all you get. :/
I know... They are just rumored after all. In any case, I'm winning by waiting. Xfire drivers will be much more mature by the time I get my 7970s, and I will be able to see the comparisons between all cards to find ones that run the coolest. I'm not the type to spend time and money upgrading a video card's cooling solution. May the coolest card win.
In addition to running cooler provided your case is well ventilated; they also run significantly quieter under load because they can use more/bigger fans than the stock blowers do.I really dont understand the hoopla over these non standard coolers. They exhaust heat into your case, which in the long run means it will run *hotter* than the reference design. Especially when put into a crossfire configuration. These are bad designs priced higher than good designs.
