Gigabyte GA-EP45-ED3P constan reboot loop
  • Thread starter Deleted member 12106
  • Start date
D
Guest
Here's the deal, these issues are all pre-os, has nothing to do with the os, it doesn't make it far enough to get to the OS.
Randomly, this board puts itself into a reboot loop. When I can get to windows, it works fine for hours, occt'ing, games, idling, for hours.
Some times it gets in this tizzy, like last night, for example, I was in the bios, it just shuts down, and reboots, and repeats until I stop if.
Unplug the PSU, wait a few min, power it up, same thing.
I am not sure what the deal is. Google hasn't turn up anything.
I am at ends. I haven't even had this board a week.
Everything is running stock speeds, I have pulled the board out and tried another case to make sure there is nothing under the board shorting it out.
I have also tried it with no fans, and no optical drive plugged in.
I have also tried it with nothing plugged into the headers for power switch, reset, and led's.
This one has me stumped, I have tried all of the basic trouble shooting stuff.
Okie dokie. Remember the first rule Don't Panic.
Actually this is pretty common. We even have a name for it "Gigabyte stoopid mode".
Try this.
Go gigabyte.com and making absolutely double damn sure you have the right board model number etc get the latest bios for your board and put on floppy or USB stick whatever. Explode any downloaded .exe so you have the raw bios file, which is all you need if you use the Q-Flash (look at bottom of screen for F key at main/first Bios Menu Screen. )
Take the side panel off, have a jumper handy for clearing the bios.
Boot, go into bios and "Load failsafe Defaults" (or whatever they are calling it these days)
Save and exit.
When the machine starts to come back up, cut the power with the switch on the power supply.
With the power supply off, hit the front panel power button a couple of times to completely drain the supply.
Install the cmos clear jumper.
Take note of the orientation and remove the cmos battery from the holder. (see manual if necessary)
leave machine for at least one full hour.
reinstall the battery
remove the jumper
switch power supply on
fire it up
go into bios
again load factory defaults.
save and exit
on reboot - go into bios
start Q flash
flash bios.
save settings and exit.
reboot go into bios and set ONLY the settings you need for the machine to function properly. Disk options etc. NO OCing. Set memory voltage to manuf specs but leave timings on auto.
Use the machine, tweak any bios settings for full functionality or options you want but still no OCing.
See how that goes and let us know if you still have any issues.
What is happening is the "watchdog function" that on bootup tries to make sure all is well and if not reboot and automatically adjust bios settings, has either gone insane or there is something in your bios settings it does not like but cannot fix on its own.
It is "normal" after making certain changes in the bios the machine will reboot when you save and exit and then reboot itself one more time.
It is "normal" if you set something crazy in the bios, for example a FSB that is just not achievable, the machine will reboot itself about 4 times attempting to adjust voltages and timings etc. to make whatever you did, happen. It will after 3 or 4 reboots give up and reset to stock speeds. In extream "stoopid" cases it will just continuously reboot and you have to cut the power and reset the cmos.
(I saw where you said you are not OCing yet, with the above just letting you know what is "normal" operation. )
If you still have trouble after the cmos super clear, be sure to give us your system specs a link to your memory on newegg is ver helpful. most performance memory needs extra voltage and lots forget to give Vdimm the +.2 V or whatever that is needed to run it stable.
I had an EP35-DS3P that did this shit too.
I put up with it for over a year until I sold it
EP45-UD3P did this also until the latest beta bios release. I am running f10e with no more problems or reboots and improved stability. Might look into a bios for your board to see if anything is available. The latest official on the gigabyte site might not have the fix but the beta's floating around are pretty good.
Try this.
Save and exit.
remove the jumper
fire it up
go into bios
save and exit
start Q flash
flash bios.
Will try tonight.
Ok Bill, did what you said.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227298
Here is my ram. Bios had it set at 1.8v, jumped it to 2.2.
Bios is all set right now with correct boot order, no splash sreen, disabled serial, etc. Nothing overclocking yet.
I was overclocking with this board, but, it just freaked out a few days after I had the system pass occt, so I reverted everything back.
The issue isn't so much the stability of the system, its being able to use it. If it won't get past the bios, its more or less worthless.
Which firmware did you upgrade too? 2.2V is a bit high on the ram. Did you try using one stick of ram at a time? PSU has stable voltages?
So it is still doing it ???
Hate to say it but there are a few that are just borked. So just gonna toss some stuff out there. I hate these, I had one and it took days to get it to stop and frankly I never did figure out exactly what I did to get it to behave.
Just checked the ram, 2.2 is manuf recommendation. Might lock/set the memory mulitplier at 2.0 to underclock the ram and reduce the voltage to 2.0 just to see if it is "twitchy" ram. Sometimes the custom SPD settings programmed in are a bit agressive if left on "auto". /shrug.
Some random thoughts.
Make sure (lol dont know how) that heatsink is not overtightened causing the backing plate to short out solder contacts under the board.
Video card fully seated (some cases have a misalingment issue with the card slots causing the card not to seat well when it is screwed down properly. Look at where the card fits the slots and if the gold "fingers" are all the same depth or not visiable at all. Rare but I have had one or two where a folded up piece of paper under the vid card "bracket" where it is screwed down on the rear of the case stopped random issues.
Cant think of anything else atm, above is very rare , but it seems like everything else is ok so I have to grasp at straws. Might try turning Hyperthreading off, dont know why I said that LOL. worth a try.
LOL give credit where due. Old Hippie came up with that here as far as I remember.
It seems to be working.
Reflashing the bios to the latest on their site seemed to work. I have been in and out of the bios and tweaking it.
It's still running occt from the other night at 3.6ghz.
I *think* the issues are past.
I am getting my corsair H50 on Monday, so, we'll see. Want to push this CPU to 3.8-4ghz.
Well today out of the blue, just surfing the web, it shuts off. No error, no BSOD, just shuts off.
Hitting the power button does not being it back. I flip the switch on the psu from on to off then back to on. Hit the power button, just a quick flick of the leds and off it goes.
Repeat the psu on-off-on and the same. Did this like 4 more times, then finally let it set a few min. Now, it boots right up like nothing...
At this point, I am strongly considering RMA-ing the motherboard and the power supply, just to be on the same side. I am not sure what warranty, if any is left on the PSU.
Also, I am running it overclocked.
This perplexes me. I can OCCT with the linpack test for days at a time. I can game for hours at a time, the, just out of no where shuts down.
It's almost like there is a short, but I had checked and triple checked everything. In fact, this is another case altogether from when the first round of issues cropped up.
Later today my H50 will be here, so, I will be tearing out the motherboard to make sure nothing is under there. I am posting this from the system, in question, so IDK.
Wow this is interesting. I am having the same problem with my comp and it has the ud3p. Mine ran rock solid oced for around a year though. I thought it may be a blown cap or something though. Would the bios just randomly start doing something like this, or would it be a problem out of the box?
Edit: sc0tty8, does your comp work after you reset cmos? Mine does like half the time. Sometimes it takes a few resets for it to work.
I haven't done a cmos reset until I did the bios flash.
Another weird anomoly...Audio started getting cunchy-like. I plugged in my headphones, and the screen that pops up to ask me wtf i plugged in crashed borderlands to desktop.
The green port that I plugged in the jack to was flashing like a night at the disco. So, I thought nothing of it, and went back into my game, no audio.
I was also going to reply to this thread, except everything was like meth head fast. Typing, my typing rate was like sky high. I'd hit a button, and it would type out like 6-8 of that letter.
Loaded up occt once, and the guys in the intro swinging the hammers, yeah...they where going like it was free speed day. It was like when you run an application designed for a 486, on a brand new machine, like the machine is too fast for the apps.
IDK. It was weird. I booted it and walked away to finish the dishes.
LOL, yea mine does the crunchy static sound thing. But only once it is frozen completely. Oh well, guess I gotta take it all apart...
My new cooler is here, so, I am tearing mine down.
I am really debating if I should just rma this board or just go core i7 lol...
Yea, I decided that if I need to get a new mobo I am going i7. No sense spending more money on older tech imo.
I am trying to find a guide that explains in more detail what the settings are in the bios, and why I care, however, google isn't turning up anything useful, anyone have some insight? I think I hit a Plataea, I can not get windows to post at 3.8.
You need to adjust the CPU reference voltages.
In the EP45-UDP3 thread there is a list of my BIOS settings I used to get my Q6600 stable at 3.84Ghz.
Making sure the RAM timings and voltages are all set manually is also key.
If you are going to be overclocking, you need to know what many of the settings are for as they will determine your cpu temps and ultimately the stability of your machine. There are lots of threads on this forum and at other forums that explain how to OC and what the different settings in a bios are for. I don't remember where I looked to OC my machine but it wasn't long and it was not difficult. :) Good luck with it! I am sure you will find a good OC.
My board did this, just got a ED3P and yanked it, seems it's hit or miss whether you get this issue or not. returning it ASAP because it's a large paperweight. Back on my Abit IP35-Pro now.
