Get Laptop to be able to use remote connect application when the screen is closed
Discussion in 'Mobile Computing' started by ng4ever, Sep 8, 2018.
  1. ng4ever
    ng4ever Flaccid 4Evar
    850
    Feb 18, 2016
    I tried everything and it seems to not work now :(
    The laptop screen goes off when I close the lid even when I set it not to do that.
    Any solutions ?
    This is Windows 10.
    I don't want to keep the laptop open.
  2. IdentityCrisis
    IdentityCrisis [H]Lite
    104
    Oct 29, 2012
    Change your power settings so the PC doesn't shut down/ sleep when you close the lid. Then verify windows is set to the right power plan?
    pendragon1 likes this.
  3. pendragon1
    pendragon1 [H]ardForum Junkie
    11,539
    Oct 7, 2000
  4. IdentityCrisis
    104
    Oct 29, 2012
    I realized you mentioned you messed with the settings but it didn't help.
    Verify you're running the profile you modified. You can either go into petpo options or click on the battery icon and verify you're running high performance. I dislike windows 10s power profiles because you can sort of manage them from 2 locations but it also depends on the manufacturer or something.
  5. pendragon1
    11,539
    Oct 7, 2000
    that popped something into my head, make sure there no oem software power manager.
  6. YeuEmMaiMai
    YeuEmMaiMai Death Incarnate
    17,078
    Jun 11, 2004
    in windows you have to set the lid switch to "do nothing" and then shutdown on battery power and ac power to never
