- Aug 5, 2013
I've been informed the new AMD cards aren't being detected by the survey.
That list is a guesstimate at best. Quite a few people, including me, do not participate in the hardware surveys on Steam. My current machines would have added to the 5070 ti and 7900 GRE total.33% more 5070's over the Ti.
I was of course right about the supply being split.
No 9070 or XT listed. This means there are likely more of each 50 series on the market than 9070/XT combined. What happened to AMD's huge supply?
Why a 5070? Judging from your sig you already have a 5090 and a 5080. IMHO one of each is more fun that 3 NV cards. I'd go for the trifecta - 5090, 9070XT and B580. So far I have the 5090 and B580. Sorry if I'm feeding your addiction.Ended up picking up an MSI 5070 Gaming Trio the other day to tinker with. My addiction to video cards continues I guess..lol. Will have some time tomorrow to mess around with it, so it should be interesting.
Basically just for fun I suppose. I had a 5070 TI that I sold here in the same rig that the 5070 is going into, so it's nothing other than a basic addiction at this point. I thought about an Intel or AMD card, but nothing jumped out to me there and though this machine is a back up machine I need it to function for when I have some buddies over for a LAN party.Why a 5070? Judging from your sig you already have a 5090 and a 5080. IMHO one of each is more fun that 3 NV cards. I'd go for the trifecta - 5090, 9070XT and B580. So far I have the 5090 and B580. Sorry if I'm feeding your addiction.
Their MSRP model is a mini dual fan card.I saw the RTX 5070 in person today in the store, from MSI, really small card, i.e. pcb, I think it's smaller than my RTX 4070 super.
It's an MSI, but I don't know which model, it has two fans and a cooler in the extension of the PCB, this second vent blows out into space.Their MSRP model is a mini dual fan card.
Fine for itx builds or something, but a scam for the price.
I don't think so, probably never will, I saw that GPU in person, the PCB is ridiculously smallSo is this card beating 4090 now?
I think I know the issue. Most people who run onboard graphics leaves it on by default and I will say that I use the onboard for my secondary monitor to keep the AMD clocks idling correctly. The onboard graphics always show as the primary GPU in my computer when running on Radeon. What is really odd is that when I run an Nvidia GPU, the Nvidia always shows as a primary instead of Radeon. I believe ARC shows secondary as well according to my testing.50 series results for May.
Still no 9070/XT but it does seem like a detection error at this point.
The 9070 appears if you use the expanded view.I think I know the issue. Most people who run onboard graphics leaves it on by default and I will say that I use the onboard for my secondary monitor to keep the AMD clocks idling correctly. The onboard graphics always show as the primary GPU in my computer when running on Radeon. What is really odd is that when I run an Nvidia GPU, the Nvidia always shows as a primary instead of Radeon. I believe ARC shows secondary as well according to my testing.
0.18%, ouch. Apparently the 5090 alone sold twice that amount, the 5080 roughly 3 times that amount, the 5070ti roughly 6 times that amount, and the 5070 roughly 14 times that amount.
https://www.asus.com/motherboards-components/graphics-cards/tuf-gaming/tuf-rtx5070-12g-gaming/
I've been trying to see the price on the Non Over Clock Edition of this 5070 from Asus TUF series. Everywhere I go, the search engine bump me to the Over Clock edition
Nope. I read that effects the fan curve only.you got the gpu bios flipped to perf mode?
1. You've got it custom watercooled. Well cooled chips use less power. You said yourself, it doesn't go above 48C. Which is probably the idle temp for most off the shelf 5070. Maybe even warmer, since they all have fan-stop.^^ One oddity I am noticing is the power draw. With the power limit at +120% and the above core/mem settings I see core voltages (with heavy GPU usage) range from 1.060 to 1.070. But the max peak wattage spike I've seen is about 215w, norm range is much lower 195w to 205w. From what I'm reading these should pull closer to 240w? No stability issues whatsoever up to this point. Just seems odd that an OC'd card would be pulling less wattage than the standard 5070 FE.
I'll take it. Low power and cool.. I like it.1. You've got it custom watercooled. Well cooled chips use less power. You said yourself, it doesn't go above 48C. Which is probably the idle temp for most off the shelf 5070. Maybe even warmer, since they all have fan-stop.
2. 50 series seem quite efficient and also temperature sensitive. In example: 5070 TI are 300 watt cards. But, if you watch youtube videos of people using them, they will often run around 250 watts. Only spiking to 300 watts, at times. You seemingly have to go out of your way to press an absolute full, sustained load, to see a 5070 ti stick to 300 watts. This is how MSI can get away with using only 4 or even 3 heatpipes, on their Ventus and Inspire 5070 TI.
Similarly, I've seen plenty of anecdotes from users, saying their 5070 don't really run at 250 watts.
3. The FE 5070 has relatively poor cooling and is loud, to compensate. That means it runs hot, and would likely use more power on average, than a 5070 with better cooling.
The 5070 ti will sit in the 290-300 power bracket in several modern games at 4k and 280-300 at 1440P, if you have a fast enough CPU. With a slower CPU you need RT or similar to push it close to the power limit. E.g. a 5800x3d will slightly limit a 5070 ti in a lot of modern games so it doesn't reach max power limit and might sit between 250 and 290 without RT on.1. You've got it custom watercooled. Well cooled chips use less power. You said yourself, it doesn't go above 48C. Which is probably the idle temp for most off the shelf 5070. Maybe even warmer, since they all have fan-stop.
Nice to see you had some good luck after all the troubles you went throughI'll take it. Low power and cool.. I like it.
I should stop playing with it but. . . last bump got me "Legendary" for a 5070. Is this like having the fastest lawnmower on the block?
