Zarathustra[H];1038847668 said:I never noticed this. Glad it's fixed though![]()
Check your link before you bitch about mine![]()
Your welcome
with adaptive vsync there might be a really quick tear but it goes back to 60 so quick that tearing is not the problem. it just sometimes causes a tiny little stutter or hitch especially with normal vsync. after getting some more gameplay time, I would say its a huge improvement overall over what it was though. I really have to look for it now and that is because I am still paranoid based on how it was performing with the previous driver. if I just dont look at the framerate then I probably will never tell.Are you getting tearing at 59fps?
yes as it fixes nearly all the vsync stutter on 680/670 cards.So does the GTX 670 benefit from these drivers?
I've seen that if I stare at the framerate graph, but my eyes don't detect anything out of the ordinary.I dont think you guys are actually getting a "constant" 60 fps. every single game I have fired up still goes to 59 fps every few seconds.
Of interest to a very few, these drivers create an artificial pixel clock limit of 330MHz over DVI, limiting the refresh rates possible on large monitors.
For reference, that is still above 60Hz refresh @ 2560x1600 so very few people care, but it broke my 1440p@120Hz setup so I'm not happy.
That might be my issue then! Thank you. I've got 3x120hz monitors. Man...
bf3 is very smooth with these. max payne 3 also, keepers.
these drivers completely screw up Deus Ex HR in DX11. it only runs at 1fps so you have to go to widowed mode to get the game going properly. its shit like this that makes me hate pc gaming. its seems its always something that gets screwed up when they try to fix other screw ups.![]()
its the start up movie in DX11 and it is a confirmed issue by many others that it runs a 1fps unless you alt tab until it gets to the menu. its the new drivers and the problem is not just on 6 series cards.Thats odd, I'm getting great FPS with it in DX11 mode. Perhaps a local setting is messing things up?
Of course I'm using the "Advanced 3D settings" in the NV control panel and I'm also running SLI, which may make a big difference if you're on a single card.
Sitting here with VSync off and 300+ FPS showing on FRAPS.
Overall these drivers have been pretty solid for me, though I've yet to really test all my normal games due to work etc.
um you must be kidding if you think WHQL drivers means anything better than "BETA". Nvidia's worst drivers, such as the one that lets cards overheat, were WHQL.BETA driver!
You brought this pain onto yourself.![]()
Guys these drivers are constantly crashing for me in BF3.
1. Constant Crashing in BF3 - I never had this issue with the earlier ones. The microstutter is definitely improved but not worth it FOR ME at this cost. The system is 690 Quad SLI at +100 core and +150 mem. Heaven runs just fine for several runs without crashin on this OC. Could it be the OC causing the crashing and somehow destabilising the hardware?
