primetime
- Aug 17, 2005
looks like a fun project! Im curious if you get some achieve some world record overclocks!
Yessir! I doubt it will get below ambient. A good thing if you aren't prepared to keep the frost off your cpu & haven't greased your socket (not sure how that last would work with a threadripper lga type chip& socket). Won't get quite as cold as the chiller Intel used to demo it's 28-core chip at 5Ghz, but it will get nice and ... chillyis that ice in the cooler? or what?
It'll get below ambient, just lookit that res.Yessir! I doubt it will get below ambient. A good thing if you aren't prepared to keep the frost off your cpu & haven't greased your socket (not sure how that last would work with a threadripper lga type chip& socket). Won't get quite as cold as the chiller Intel used to demo it's 28-core chip at 5Ghz, but it will get nice and ... chilly
sorry - bad wording - I meant below freezingIt'll get below ambient, just lookit that res.
Lol. The one on the right is not a TR4 cooler. I pulled it to rob its fan.The one on the right is the winner.
Possible. But you would also have more room there with no back plate.Since the rgb cable controller of the wraith is sandwiched between the gpu and cooler, when using a gpu with no back plate, can the tip of the cable(which doesn't seem protected) or something from there melt over the years?Or damage the sticking pins of the pcb of the gpu?
