That's your opinion. Most of the HD stuff I view isn't 'stretched and squished' that bad. I've been watching my video content that way since the late 90s and don't even notice it.Stretched and squished stuff is god-awful.
If your Laptop will drive it's display 1900x1200, it will drive this Monitor at that resolution if you have an output on your Laptop.Alright I need some clarification. I need to be able to run my laptop with vga to the monitor. When doing this with the gateway will I be able to achieve maximum rez or just 1900x1200? Also what is the overall image quality when running 360 through hdmi at 1080p?
thanks
Falcon, looking at the front of the monitor, the date sticker is on the bottom right on the back-side. It's pretty small.
Hello,
Every NTSC Standard TV on the planet is called a 4:3 set. Google NTSC aspect and find me one that says that it is 3:2, I just haven't seen that. Please post a link to back up your info here. I posted one for you?
Les
Who says that is happening? Take your 720 x 480 example.NTSC and 480i/p is 3:2, like I keep saying. 720 x 480. That's 3 lines or horizontal resolution for every 2 vertical lines, or a 3:2 aspect. HD(720p/1080i/p) is 16:9, and many monitors handle HD signals just fine, so that's not the issue.
The problem is how they handle NTSC (anything over composite or s-video) and 480i/p (component, or hdmi or other input).
Why do you think scaling 480i/p (a 3:2 signal) to 2560x1600 (a 16:10 display) looks great?
Everything would look squished one way or another (which way depends on whether the output device is set to 4:3/standard or 16:9/widescreen)
It needs to be scaled to a 4:3 or 16:9 sized box to look proper and not have squishing.
thanks
Ok so if that is true, what monitors or TVs do it correctly? Is everyone doing it wrong? Is this something you wish would happen or is it happening?
I didnt say anything about NTSC displays. I was talking about the NTSC signal, which is 3:2. The image content of NTSC is typically 4:3 sure, which is why you need those other scaling options to handle it properly. Cuz 1:1 and aspect mode show a 3:2 aspect image. It's one of the few cases where signal aspect is different from content aspect.
To "back myself up" I took a ruler and measured the size of the output of NTSC and 480i/p signals when set to 1:1 or aspect and verified its a 3:2 aspect. How much simpler and concrete of proof could you get?
Oh, and first attempt to find another source: (wiki entry for NTSC - http://en.wikipedia.org/wiki/NTSC) image at the bottom: http://upload.wikimedia.org/wikiped...ns.svg/700px-Common_Video_Resolutions.svg.png DV NTSC = 480i/p = 720 x 480 = 3:2 aspect
Did you just read a bunch of stuff on the net or did you actually attempt to do any of this like I did and see the undisputable truth.
Right, Standard TVs dont have 720 lines. Their scalers squish the 3:2 signal down to 4:3 to match the 4:3 content carried by the signal.
The Dell and Samsung doesnt because they dont even have NTSC or 480i/p inputs, the Gateway has those inputs, but doesnt handle them correctly. Some smaller sized Samsungs that do have those inputs apparently handle them correctly.
So your answer is:
Nobody does this correctly in a 30" Monitor presently? My observation, Gateway comes the closest. People who own tghis monitor Rave about it with these inputs.
And by your own admission, NTSC distorts the signal also on a standard TV.
My friend it's an imperfect world.
What is your point in this thread?
Les
lol!!!
Gateway only comes the closest cuz it has the inputs??! What's the point of having the inputs if you cant even display them correctly? As soon as Dell or Samsung or anyone else build a 30" simply HAVING those inputs, they are then JUST AS CLOSE as Gateway is, which is to say, not close at all.
People who own this monitor either never tried running NTSC or 480i/p content through it, or are sub-humans who enjoy distorted content.
NO, Standard TVs don't distort the image. I didnt say that so don't put words in my mouth. They show the image exactly as it was intended because they scale the 3:2 aspect to 4:3. Gateway's scaler doesnt, it leaves it at 3:2 or blows it up to 16:10. Yeah, the cheapest televisions in the world display it correctly, and the $1500+ Gateway with HQV does not.
My point was first to see if the Gateway handled this issue correctly, then to admonish them once I foudn out it DOESNT, then to educate people to know they deserve and should demand better. Watchign every single VHS player, non-upscaled DVD, every non-HD console (even the Wii!), basically every non HD source out there come out DISTORTED is unacceptable.
Here's what you said, "Right, Standard TVs dont have 720 lines. Their scalers squish the 3:2 signal down to 4:3 to match the 4:3 content carried by the signal"
Maybe some of the sub humans on this thread who own this display will pipe in about how stupid they are...
Les
I take extreme personal offense at that; there's absolutely no rationale to commence a slew of posts with name calling and throwing insults solely because a fair number of people exist who don't view the world in the same light fanatical purists like you do.They're only subhumans if they dont have a problem with distorted images.
Why is 4:3 content sent on a 3:2 signal anyway? If 16:9 content has a 16:9 signal that would show up correctly at 1:1 or aspect on a 16:10 monitor with black borders. Besides I'm sure few people could tell the difference in squishing between 16:9 and 16:10
As for people accepting distorted images, well that has been going on for decades every time people watched movies on TV which were "formatted to fit your screen" Only recently have people accepted seeing black bars on their old TV sets when watching movies.
Why is? I couldnt really tell you, that's some kind of tech history lesson. but the fact is it's there, and admittedly one of hte few scenarios where signal aspect doesnt match content aspect. Some 16:9 content IS sent on a 16:9 signal; pretty much anything HD for example - 720p and up - which is why we can enjoy those under 1:1 and aspect modes and have no problem.
I'll admit when you use the 2 close "pairings" the distortion isnt massive, but it's still there and you do notice it. I had to watch standard def TV in a 3:2 aspect box for a while there and Jon Stewart from the Daily Show just never looked right.
I will say that not everyone watches movies on tv, that not every channel does format to fit the screen, and that more often than not that means pan and scanning, not squishing. In fact I'm hard pressed to remember a time when they did decide to distort instead of cut off the sides.
Well then the problem is not so terrible after all. As for distorting movies, I remember seeing that 'altered to fit your screen' disclaimer a LOT! (unless they say that for pan and scan as well)
PS I can't stand John Stewart in any aspect![]()
It can and almost always does mean pan and scanned. I think the only time there is squishing (changing the aspect) is when there is a combination of both - but even then, that has to be extremely rare.
The issue is just really easy to fix, which is why its so frustrating. And considering the cost of these monitors, its not acceptable and I don't know why they dont put in the 2 modes to fix it. It's not any more complicated of a scaling operation than anything else they already do. I think the reason if anything is just ignorance of the problem (they dont realise there is one).
Maybe the people contacting Gateway about monitor flaws could ask them about this.
Oh hell yes it could! That's why its even more frustrating.
If BenQ could produce a firmware update that gave their 24" the option of 1:1 and aspect in the first place, surely they could put in 4:3 and 16:9 scaling modes as well, as its all the same kind of operation.
Ok im left a little confused by all the conversation...
if you have a 16:9 image you are viewing on 1:1...there would be black bars on top and bottom of the screen right? ...at least on a 16:10 monitor...
Really..whats the difference between 4:3 and 16:9 scaling modes and 1:1. 1:1 will preserve the origional aspect (size and relationship of width to height of the picture) correct? so if 1:1 preserves this..whats the difference between 4:3/16:9 and 1:1
That is exactly what I thought. But according to Deusfax the 4:3 content is sent out in a 3:2 signal. So scaling it up keeps the 3:2 ratio instead of converting it to 4:3 as old TVs do. If the signal is in the correct ratio then everythinhg is fine.
It's only an issue with NTSC (composite/s-video) and 480i/p where the signal is a different aspect (3:2) than the content it carries (either 4:3 or 16:9.)
HD signals like 720p are also 16:9, but the signal is the same aspect as the content, so yes, 1:1 and aspect mode are what you want, and a 16:9 mode there would be redundant and do the same thing as those other 2 modes.
It's really easy to verify too. Plug an SNES or something into the monitor, and you can see the displayed image has a 3:2 aspect on 1:1 and Aspect modes. Yet you know better, that the SNES was designed for use with 4:3 televisions, where everything is not distorted obviously when used with them. So when viewed on a monitor in those modes in a non-4:3 aspect, there IS distortion.
The blackout issue sounds like a DVI signal integrity problem. It's quite tricky to get this right, especially through switches. That's why DVI KVM and HDMI switches tend to cause the same blackout problems. Dual-link DVI as used by 2560x1600 monitors adds further to the difficulty. The price you pay for multiple inputs (as in the XHD3000) is the need to embed an input switch in the monitor, and this can cause trouble. That's why repeaters which re-generate the signal are sometimes used within switches, but those don't always help either. The quality of the switch, DVI transmitter (in the video card), receiver (in the monitor), as well as the cable quality and length all matter. Slight problems anywhere in the chain, and you get problems such as blackouts. A short blackout basically means that the signal has momentarily degraded to the point where the receiver can't process it. It indicates marginal performance somewhere on the signal path. I hope DisplayPort turns out to be less finicky.
Interesting observation. I've seen this with KVM switches in the past. Do you think there is any difference from Nvidia or ATI on this?
Hi,
Les
The manual for the monitor actually states not to use KVM switches with it. Probably just being cautious. I use a KVM switch on the VGA port with no problems.
