holy balls when do these deals start?
You know you can get 2GB Laptop ram for $50 or 1GB for $25
If it had XP home the deal would be hot, however, having used vista and the celeron m, if you decide to buy this plan on getting more memory. Overall this is a great deal though, where else can you get a new laptop for 300 bucks
It's a celeron... You may save a greenback or two, but you'll need those later for reconstructive face surgery once you get done punching yourself in the face for buying such a pile of shite.
Core 2 was loosely based on the Pentium-M, but it's a couple of generations newer.The moblie Celerons are fine. They are the exact same as the Pentium-M but with speedstep disabled so they run full speed all the time and battery life is less as a result.
Further info: Pentium-M chips are similar to the Core2Duo archetecture.
Celeron's are massively castrated. The one in that laptop is probably conroe core based except with 1/4 or 1/8th the amound of cache.
I have a 2.53 ghz Celeron. Based on P4 core in my work computer. It's SLOW. Bogs down on webpages, word documents, it's miserable. I don't think my old, old P3-800 got bogged down as much of this pile of crap does.
That means my laptop is worth less than $300.
I wonder how poorly it's gonna run Vista with only 512 ram?
Is the celeron a really bad processor to use with Vista?
They aren't that bad. The Merom-based Celerons are single-core with 1MB cache. I've used one with an 8600M GT (also crippled, hurrah for DDR2), and it was alright for gaming.Celeron's are massively castrated. The one in that laptop is probably conroe core based except with 1/4 or 1/8th the amound of cache.
LOL @ 'maths'...my Ti-89 Titanium would smoke that thing
Too much Look Around You.
Sorry guys two of them are mine.
Limit of one per household*
If you want more than one, you'll probably have to go to more than one store. Or at least the same one at two different points during the day.
But at this price, I seriously doubt you'll have the time to do either.
i would buy $450 one, it will last couple of years. It is only $150 expensive from celeron, but if you see you will get double the memory double the hard drive, double the processor (not to mention at leat three times faster).
