FerretBoi said:I Tested 2 Dell 2407's and 2 Gateway 2485's here is a unprofessional pros and cons of both of them =p
Dell ~ The image was solid and uniform, I had no issues with ghosting, blurring, or flickering as I did with the 2485 in the 6 months I used it. This was the main reason why i liked it.
Dell ~ The 2407's lamp wasnt very bright altho i didnt notice the severity until I had the 2485 side by side with it, I didnt like when scrolling thru text that white letters would turn greenish. Obviously the banding issue. I was able to match the colors of the dell to the 2484 but i had to put the monitor into gaming mode which enabled the Fuju chip and increased banding issues.
Gateway - The Colors! Oooh the brightness! Everything was so clear and crisp it almost melted my eyes. The gateway no doubt has the better picture of the 2 and i wish i could have kept it if it wasnt for...
Gateway - The flickering in games and in the desktop, this monitor acts like a 80's TV with a faulty optical sensor for detecting light and dark rooms. After hours it would give me a migraine because of the constant flickering of the screen. Motion Blur in WoW was very noticeable also.
These issues happened in the desktop also, so no matter what FPS you are achiving it will always happen, Its just the nature of the Monitor.
For those having flickering issues, I suggest updating your video driver. Also, if you are using DVI, try playing with the DVI video mode functions under the Digital Panel Properties setting in ATI Catalyst Control Center. ATI driver has this feature, not sure if Nvidia does at well.
