M
MantisIT
Guest
/nevermind
On another note, I found a good dead pixel program and my FHD2400 does indeed have a dead pixel (found one so far, but I'm sure there are more) and some backlight bleed. So since I still have a few days left on the 14day return limit, I'm going to exchange for a new one at BestBuy (better not try and give me a hard time). You would think you wouldn't have to worry about these kinds of things when spending $600...
Also, when using VGA did does anyone else notice light snow/noise in the picture?
How much did you guys pay for yours? I might go check it out...but 500+ for a tn panel scares me
Why do you call it a "TN" panel? What do you mean by TN?
Also what is the difference between the FDH2400 and the FPD2485W?
I was originally planning to buy a FPD2485W, but now these FDH2400's are out.
Now i'm debating which to buy?
after a having my FPD2485W for a few days I traded it in for the FDH2400.
the FPD2485W for some reason would not work with 1080p at 1:1 on my 360 (Feb 07 model) but the FDH2400 does it with NO problem. it does have a slight Color effect when I'm not viewing it head on but I only notice it on very dark colors (blacks and dark Grey's) Colors themselves don't seem to have a noticeable effect on it.
There was ghosting on the FPD2485W but with overdrive on the FDH2400 I don't notice anything. If I take my cursor and run it over the dark Grey in this forums I could see it with overdrive turned off (same with my FPD2485W) but when I have Overdrive on I don't see any what so ever.
Color wise I prefer the FDH2400 I love the glossy screen, everything just has such a vibrant pop. I love the design of the FDH2400 much more than the FPD2485W, and it still has the 90* tilt function with HDMI.
The color shifting thing doesn't bother me at all, and I love the vibrancy that the FDH2400 has. it's a winner in my book.
If not, it's a close contender for the top position. I guess it depends on you needs, but for certain features it definitely has all others beat. If I was in the market now, I wouldn't be considering any other 24" display.is this best 24" gaming LCD out now or what?
What is a TN panel? and what does this monitor lack in your opinion?
Some people also don't like the glossy screen, but myself and others consider that a desirable feature.In my opinion the monitor lacks really nothing. I know there are people that can't stand the viewing angle / the tiny bit of color shifting, to me I don't get bothered by it.
hey guys ... after deciding to go back to 24 inch instead of the 30 i bought this monitor today and wow ... its amazing.
Can someone help me find if there is any dead pixels or bleeding?
dark? hell no .... this thing is bright
I came from a 23 apple cinema display and i never experianced this good of a monitor till now.
I still need help with checking for dead pixels and bleeding?
You got it? What's your overall opinion of it and where did you get it from?hey guys ... after deciding to go back to 24 inch instead of the 30 i bought this monitor today and wow ... its amazing.
i just tried connecting my usb mouse through all(x4) of the usb ports .... no light on the mouse? anyone having this problem or am i just not doing something right?
If the box didn't contain it, then you need to locate one and connect it between your monitor and computer, otherwise you won't get any USB device working when hooked up to your monitor.i didnt see any usb cable?
