tnx for the comments. the 244t is a fanominal display, the only problem right now is it doesn't do 1:1 pix so my hdmi ps3 plays 10% vertical stretch. This can be fixed when a cheap blu-ray ROM is available for the PC.According to your signature, you already own a Samsung 244T, so I'd say unless you have a problem you're trying to fix, you're good to go. They are very similar in capability. The Gateway has HDMI, is a much faster panel, and has a glossy display. However, on the flip side, the recent backlight bleed creep we've been reading about compounds the any thought of moving, as the technology used on the 244T has no such issue.
I use the 244T at work and this Gateway at home, and am happy with both. They are slightly different animals, but there is no real advantage in moving between the two unless you're trying to fix a problem, and don't mind risking new ones.
