Is the gateway FHD 2400 the best 24inch lcd on the market for the money? im thinking about buying one for christmas!
It depends on what you need.
If you want TONS of inputs, it's a great choice.
It also does pivot, PiP (Picture-in-Picture), and HDCP.
You have to decide if it does PiP the way you want -- it lets me do PC/PC PiP, but because it does, it doesn't do DVI/HDMI PiP. You usually get one or the other.
The glossy panel is a plus for sharpness and contrast, but a minus if you are going to use it in a reflective environment.
The panel is a TN-type, which is good if you are a gamer. It is not good if you will have people standing around you that you would like to watch what you're doing. You will also need to check for backlight bleed when you get your unit.
Photographers usually steer clear of TNs, but I've gotta say, the technology has come a long way, and this panel looks excellent.
This unit was the best for my needs. I positively love it.
