Gaming rig specs, any suggestions?
So I'm ready to upgrade my gaming computer. What do you guys think of the following specs? Is this machine balanced? Will I be able to overclock this CPU later on (it's not unlocked)? Is this a good motherboard? Any recommendations on a similar motherboard but with integrated Wifi?
Motherboard
Asus P6X58D Premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
System Hard Disk (Raid 0)
(2x) Intel X25-V SSDSA2MP040G2R5 2.5" 40GB SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167025
Storage Hard Disk (No Raid)
(2x) WD Caviar Green WD20EADS 2TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136344
Processor
Intel Core i7-950 Bloomfield 3.06GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Memory
Corsair Dominator 6GB (3 x 2GB) DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145295
Power Supply
CORSAIR HX Series CMPSU-620HX 620W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
Video Card
EVGA GeForce GTX 470
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550
Disk Drive
ASUS Black 24X
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Case
Thermaltake Element V Black Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133178
I'd recommend getting GTX460 (1GB or 768MB) at that price range, it's going to be a small bit faster than the HD5830. The next step up is the HD5850, then the GTX470, then onwards.
You processor is socket 1366 and the board is 1156... or am I missing something?
You either need to change your Mobo/Ram or change your CPU because you have a Socket 1366 CPU and a socket 1156 Mobo and Dual Channel DDR3 (You'll need Tri-Channel DDR3 with that CPU)
EDIT: Staypuft beat me too it!!
I would also recommend a bigger PSU in case you want to future proof your rig in case you want to overclock or upgrade graphics or run CF/SLi
Edit: For such a nice rig you should upgrade your graphics card.
I was actually trying to get a smaller PSU to generate less heat and consume less power. I don't plan to add another video card, and if I do I could always get another PSU then. Unless you think a 620W won't be able to handle this setup or this specific PSU is a bad selection, I'd like to stick with the 620W if possible.
Which card would you recommend? Also, don't you think the HD 5830 will be able to handle every game out today with maxed settings? Even though it may not look like it, I am trying to keep the price down as much as possible.
I was actually trying to get a smaller PSU to generate less heat and consume less power. I don't plan adding another video card, and if I do I can get another PSU then. Unless you think a 620W won't be able to handle this setup or this specific PSU is a bad selection, I'd like to stick with the 620W if possible.
Oh, the PSU is fine then. I just thought you were trying to go all out and future proof it haha.
and do you plan to get an aftermarket cooler for that 950? I would highly recommend it.
I did plan on going liquid or purchasing an after-market cooler when I overclock, but I haven't looked at them yet. I'm open to suggestions, I don't think newegg is a good site to browser cpu cooling components. I'd like to avoid going liquid if possible, because I'm always afraid of a failure.
You could always look into the Corsair H50/H70. They are prebuilt, self contained, sealed water cooling kits. You mount the block and the fan and you're good. I personally have one and its zero maintenance.
EDIT: Heres a link for a review. http://skinneelabs.com/corsair-h50.html This guy does alot of the testing for the WC community.
I'll take a look at the review later today when I get off work. From a glance, it looks like I may have trouble mounting the intercooler in my case (especially the H70). I guess I need to give them a call or look for some photos ;)
I dont think you'll have any problems. It fits in the rear exhaust but you have to change it so the fans intake air instead since it'll be cooler. I'll try to look for some pictures if you need.
It sounds easy enough. I can find pictures or call them and ask for some, don't worry about it :D
Do you have any input on the video card? I've always thought nVidia was better but it seems ATI is the better choice for my build (but I'm not very knowledgeable when it comes to the newer generation of cards).
It depends on what resolution you plan to game at
I use 1920x1200 and play games in windowed mode. I also have two displays, I game on my primary in a window and keep mail and music and IM on the secondary.
Right now I just play SC2, I plan on using this machine for D3 as well. If the window resolution matters, it's close to 1920x1200. I size the window so I can just see the task bar.
I would go with at least a 5850. They may play your games now, but what about later? I dont know, just something to think about.
I don't know that much about ATI/Raedon graphics though so dont take my word for it!
I would rather just get one card and not use SLI/Crossfire. I think I'm going to change to the GTX 470, it looks like a better overall card and nVidia has always impressed me. The GTX 480 is for sure out of my price range. I'm trying to keep the cost down and I can't tell if I'll ever notice the difference. What do you guys think? I'd love to save the $80 by going the ATI route if possible.
Another question I guess is which is better, the HD 5850 or the GTX 470? haha
Thanks for the input Stalker and Blu3phoenix! <3
I think the 5850 is a little slower (a few frames) than the 470 from what I've found. I would probably go with the 5850 if you're trying to save money.
Is the 5850 cheaper than the 470 though? Fermi prices have gone down dramatically the last couple months
in my opinion i'd go for the i7 930 w/ with 460 gtx. (cheaper price)You also have to have a 1366 socket mobo.
Thumper is right, I can just get the Asus 470 for $300. So it looks like I'm ready to buy the rig. I can't wait for dual SSD in raid ^^
I would switch platforms entirely since the primary usage of this PC is only gaming.
Alternative setup:
$359 - Intel Core i5 760 CPU + Asus P7P55D-E Pro Intel P55 ATX Motherboard Combo
$92 - G.Skill Ripjaw Series F3-12800CL9D-4GBRL 2 x 2GB DDR3 1600 RAM
Total: $451 plus tax and shipping.
The i5 760 is just as fast as the Core i7 950 in gaming as shown here:
The 2.8Ghz Core i7 930 only provides about a 2 to 5FPS difference as shown in this review:
http://www.legionhardware.com/articles_pages/gaming_the_core_debate,1.html
Additional proof: The $1040 3.3Ghz Core i7 975 Extreme Edition CPU is only 15% to 30% faster with only a specific set of games and video cards:
http://www.xbitlabs.com/articles/cpu/display/cpus-and-games-2010.html
So considering the the i7 975 is faster than the i7 930 and yet only provides 15% to 30% under ideal conditions, the Core i7 930 is definitely not gonna be that much faster than the i5 750 or i5 760. In addition, There's very little real world difference between triple channel and dual channel RAM in real world apps and games. Also, there's very little real world performance difference between Dominator RAM and any cheap set of DDR3 RAM. So for a savings of $329, you're getting very similar performance in games. So I highly recommend going for the above build or at least switch to the Core i5 750 ot 760 CPU for a better bang for your buck value
Other notes:
- For SC2, do not bother with a Crossfire or SLI setup as SC2 does not scale well or at all with those multi-GPU tech. So basically for SC2, stick to a single video card.
- The GTX 470 is faster than the HD 5850 but uses significantly more power and generates significantly more heat. You might want to take a look at a few reviews if that extre performance is worth the extra heat and power usage.
On a related note, the XFX HD 5850 is only $255 until 9/19:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477
- However do note that the HD 5850 and GTX 470 are complete and total overkill for SC2.You really won't notice that much of a difference between the $220 GTX 460 1GB and the GTX 470.
- Definitely ditch the Corsair 620HX. It will be enough for your planned and my above alternative setup BUT it's a four year old PSU design that's already been superseded by newer, better, and cheaper priced PSUs:
$80 - Seasonic S121II 620 620W PSU
$90 - Corsair 650TX 650W PSU
$120 - Corsair 650HX 650W Modular PSU
$120 - Antec Truepower New TP750 Blue 750W PSU
Every single one of those PSUs are better than the Corsair 620HX in terms of quality and power output quality yet are significantly cheaper. Also note that every single one of the above PSUs are made by Seasonic, the same manufacturer for the 620HX. So basically, zero reason to get the 620HX these days in light of its replacements.
- The Corsair 950TX recommended earlier is complete and total overkill for your planned setup but it's very very well priced.
- Ditch the Intel 40GB SSD RAID 0 plan. It's only a little bit faster than the Intel 80GB SSD but now you lose out on TRIM. Considering that TRIM is fairly important to the longevity of a SSD and its performance, it's definitely worth the tiny decrease in performance and for the same price:
$200 - Intel SSDSA2MH080G2R5 2.5" 80GB SSD
Alternative setup:
Other notes:
Thank you for this amazing response! As far as I can tell I will probably go with all of your recomendations. When you talk about TRIM your talking about using 2x SSDs in raid right? Yeah I just found this article and it explains what your talking about http://www.anandtech.com/show/3618/intel-x25v-in-raid0-faster-than-x25m-g2-for-250
Yeah when you're running a RAID array of any kind with a SSDs, you lose out on TRIM.
I guess another question I have then is it worth upgrading from my E8400 =/
Depends on the games you're planning on playing. Some games will see a dramatic increase in performance. Some won't.
Would you recommend XFX? I'm having some difficulty determining which company I want to go with. My thought process is just stick with Asus since the mobo is Asus but from what I can see the Asus warranties aren't competitive. Also, what are your thoughts on G Skill? Why not stick with a name brand like Corsair for something like memory?
