None yet I beleive... still waiting!WHERE ARE THE REVIEWS!?!?!?!?
U have 2 guys here and a link I posted previously. What else do you need?
xkon can you post larger image, I can't see very well.
Raise your vcore and max out that board voltage.360Mhz so far with +0.1V for CPU and NB. 370Mhz and Windows won't boot with +0.1V.
http://www.wilke-service.net/gallery2/d/11799-1/F_I90HD_360FSB_0_1VoltagePlus_CPU_NB.jpg
My Local FRY's has these in stock and I have one waiting for me to pick up after work on the way home!
I'll test it out with my C2D E6700 or a C2D Xeon 3070 that I may decide to borrow from work
Yeah, Frys has them at all their stores yet I can't get one distributor to get off their lazy butt and get them in stock. It isn't like Abit is just hording them in some warehouse in Fremont. They are out there grrrrr It's killing my sales.
I wish I could sell hundreds at a time because then I would just not use a distributor.
I was considering ordering from you after we found out more on the OC potential.....but I just can't pass up a chance for immediate gratification by picking it up today, not to mention I can easily return it within 30 days if my results are not satisfactory
The BIOS?this is the last past of the puzzle that I need.
The BIOS?
I took a look with the old AWARD BIOS editor but the setup menu is unreadable. I never looked into BIOS editing but I wanted to know if the CPU multiplier could be there but hidden.
I am waiting on this board to build my new rig, I have been planning and planning it out and the time is almost here:
Silverstone SG-01B Evolution
this motherboard
E4300
Silverstone NT03
Silverstone FX121
3-80mm Scythe MNB Medium case fans
Corsair 620W
2x1GB teamgroup PC6400
EVGA 8800GTS
WD5000KS
Samsung SATA DVDRW
dammit I want this board now.
The NT06 with no FX121 is better.
Noctua fans are also great
I sell all of the Silverstone and fan products
Would that be the NT06 without a fan on it? Call me old fashioned I would rather have a fan on my CPU cooler.
the cheap 4300 or 4400 if you are on a budget
That's me Put in my order today for one. NOW I just hafta find this board somewhere!
I gotta start selling them before I cry. Stupid distributors. I cant say that enough
If you can have them to where I can get one by the end of next week I'd gladly buy it from you, say the 15th or 16. (Spring break next week, won't need it till the end.) Is the pre order still up?
DandH just got 10 of them in stock but they are not my primary distributor. If ASI doesn't get them tomorrow morning then I will purchase a few from DandH.
Even though this says "first release," I think this may be a new one. I think the shipping boards with the "evaluation ROM" actually have a beta bios.There is finally a BIOS folder for F-I90HD and the latest is :
m612a11.zip
BIOS release V.11 for F-I90HD
Release information:
[ENGLISH]
1. First release.
2. BIOS compiled date: 2/11/2007
So I guess there is nothing new but now you can remove the EVALUATION ROM message at boot I beleive.
can you check on max FSB. It seems ppl are hitting a wall at 350FSB which is not great, but not that bad.
I'm happy to report that this board is definitely a keeper! I was able to Overclock easily to 3.25ghz on my C2D E6700 (3.25x10) and my gaming perfomance with BF2142 is comparable to my 680i with the same components and overclocks! The OC is 100% stable after an hour of playing BF2142 and I have not detected any Snap, Crackle, Pop from my X-fi during orbital strikes!
My config:
Fatailty F-I90HD
C2D E6700 @3.25 ghz (325x10 1.325 Vcore, 1.87 NB)
2GB Patriot LLK 4-4-4-12
BFG 8800GTS OC @619 1800
X-Fi Fatality
160GB Raptor
Seasonic M12 700W PSU
USB DVD/RW
Motorolla Wireless adapter
Gateway FPD2485W 24" LCD
Logitech 5500D w/ Klipsch RSX Satellites
I'm going to continue to test stability and gaming perfomance with my current OC and then may try to see if it will go a little higher in the next few days after I see what results others achieve. Even if it will OC higher, I'm happy with the current settings and will run it as is once I transfer the system into my Fragbox.
Try the latest bios, it may give you multi control.can you check on max FSB. It seems ppl are hitting a wall at 350FSB which is not great, but not that bad.
So, Dworley, I take it it isn't many problems with using a long/dual cooler video card like the 8800 series and SATA devices?
