- Apr 5, 2007
Looks like the ATT S4 boot loader is locked:
http://www.droid-life.com/2013/04/29/att-galaxy-s4-has-a-locked-bootloader/
Yep. Verizon's will most likely be the same as well. Dan Rosenberg said RSA-2048 bit encryption. Probably not going to find a hack like the recent one he found on the Motorola bootloaders.
Show your disgust with this with your wallet people!
After buying a while lot of games my gs2 16 GB with 32 GB microSD, I ran out of space very quickly. There is only so much data you can move off to SD. My sd card had like more than 20 GB free with my internal memory at ~300 MB. I can't even get updates sometimes, "insufficient memory." I had to go to the system app manager and let it do its thing for a couple of minutes till it gave me more memory after running, and if that still didn't work, i had to make the tough decision to uninstall an app.
Yep. More and more apps are setting the internalOnly flag in their manifest as well. Apps with widgets should be setting that to begin with as well so the widgets actually function. 16GB may be enough for some people but when you get ~4GB of irremovable (for normal Joe Average User) bloat something needs to give.
