Sorry if this question has been answered already, but I was looking to put this board in my P-180 which I hear the Scythe Ninja fits perfectly in, but will it fit?
I wanted to have the option of using it in my Antec Fusion HTPC when I upgrade it in the future.
Overclocked - Try the XP120. Air flow doesn't work in favour of downward facing fans.
Hey, I've got a Lanbox Lite and plan on purchasing a GA-G33M-DS2R with a Q6600, what heatsink would you all recommend that will fit given the above parameters?
Thanks!
I've updated the Bios to F5, which gives me a 2.5, 3.0, or 4.0 divider, but I don't even SEE a lot of the options (like for ram timings and such) that I expected to (I didn't seem them on stock F4 either). What do I need to look at?
BSEL mods don't work. Covered in the early part of the thread.I found a guide in polish that state how to modify the natuve fsb of cpu intel having a low fsb.
I believe it is locked by default at 100MHz. If not, just set it to 100MHz.Also What the hell is "Robust Graphics Booster" in the BIOS? Or Option 1, Option 2 under High Speed DRAM DLL Settings? Performance Enhance? All these sound like some sort of auto-OCing gear?
Should I lock my PCI Express Frequency at something?
Does anyone know if the Zalman CNPS 7700 will fit in a Lanox lite with the DSR2 MB?
Thanks. Now I have the extra options. However, it doesn't really seem to be helping me...
If I put it at 333x9 to get to 3.0ghz, and the 2.5 divider making it 833, I get a "boot failed" message after the initial post! I did NOT buy cpu thinking i would be under 3.0ghz as G0s I've seen go 3.6. I was hoping 3.2 at least based on cooling. My ram is a 5-5-5-15... so what's the issue here? This DDR800 just can't run at 833? *sighs* All voltages are on auto.
Hi
I m from PVHK post on Hardware.fr.
I'm proud to announce you my first MOD a VDroop mod for the GA-G33M-DS2R
here is the chip to mod :
I've reducted the resistance from 2.6k to 1.7k but you can reduct it more for less VDroop (300 ohm at least)
After the VDroop mod (not perfect for instance, needs to reduct a little bit more the ressitance):
I can't even see what my vDIMM is! The only options I have are like +0.1 - +0.4, without referencing what the vDIMM would be. The lack of data this board gives is getting frustrating. Oh, and trying to run the ram at 1000 just as a test, with the CPU at stock basically killed it, so now I have to reset the CMOS, which is of course in the middle of the fscking board![]()
Vdimm is 1.8v as default so +0.4 will make it 2.2v. I thought this board had an easy cmos jumper to deal with, its out of the way and just touch it with a screwdriver for a second. I was happy the first time I had to clear this board, last half a dozen or so required removal of the graphic card.
This is the ram I have : http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Any idea what sub-timing I should look into? Or any further data on it? I posted my CPU-Z in the OCing forum thread, of what everything looks like stock.
I have the Same Memory installed with an e6750, but I haven't tried O/Cing this setup yet...
Maybe I'll give it a spin later this evening and let you know how mine works.
Huh, you're trying to overclock 2GB sticks? After my initial experiences just trying to find 2GB sticks *compatible* with the motherboards I was using, and seeing how almost everyone who overclocks memory only seems to try doing it with 1GB sticks, I instead got myself motherboards than have 1:1 dividers and then got myself CPUs with 800 or 1066 FSB so that I can keep my 2GB sticks at their stock speeds. I think you're going to find that you're almost on your own when it comes to overclocking 2GB sticks of RAM (of course in the not-too-distant future this will all change, just as there was a time not too long ago when people only overclocked 512MB sticks of RAM...)
