FS: For Honor/Ghost Recon Wildlands Game Codes
Discussion in 'For Sale / Trade' started by Ikasu, Feb 14, 2017.
  1. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    Got a few For Honor/Ghost Recon Wildlands Nvidia promos. These codes are USA Region Locked! (Although tested and can be redeemed via VPN)
    $25 Each FIRM
    The redemption is VERY different than usual. Redeeming requires Geforce experience, a Uplay account, as well as a GTX 1060, 1070, or 1080, or 1080ti in your system (Geforce experience scans your HWID). If you want to take a chance and risk it, you can try...But codes are non refundable.
    For those that already purchased a 1060, 1070, or 1080 before the promotion went live, it's just a quick redemption. I've redeemed one for myself with no issues even though I purchased my card earlier.
    heat
    PM if interested ^_^.
  2. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    ttt pm's responded
  3. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  4. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    bump, pm's responded.
  5. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  6. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  7. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  8. soekev
    soekev Gawd
    925
    Feb 26, 2005
    Is this the GR promo code that also includes the Season Pass?
  9. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    Nvidia gpu promo. In order to get the Season Pass, that's part of the MSI Bundle. You actually have to physically have bought a card and have the invoice + serial number to register via MSI. So this will only work if you just bought the card. Which most people would get the promo new to begin with. So no real way of redeeming the season pass.
  10. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  11. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  12. SPARTAN VI
    SPARTAN VI [H]ardness Supreme
    6,376
    Jun 12, 2004
    What if I had two PCs, one with a GTX 1070 and the other with a GTX 970. Would I be able to buy 2 codes and redeem both if I simply redeemed the first one on the GTX 1070 machine, then swapped cards to redeem the second code on the GTX 970 machine?
  13. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    I believe it's serial number based. If you want to try it..you can...but no guarantees it will actually work...I believe it's one per gpu.
    SPARTAN VI likes this.
  14. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  15. SlayVus
    SlayVus Limp Gawd
    186
    Jan 13, 2011
    Code activation is based solely on whether you have a 1070/1080 installed in the system, not the serial number of the card. This is only for GeForce Experience activations, not the MSI activation.
  16. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    It's one per system. They are using a method to keep tabs on system info. Whether it by SN, system HWID combinations, unsure of how they keep it recorded. Even making a new geforce experience account will not let you redeem more than one.
    MSI activation is indeed different. Separate process, with registration of your GPU with invoice/sn required.
  17. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  18. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  19. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  20. KickAssCop
    KickAssCop [H]ardness Supreme
    6,242
    Mar 19, 2003
  21. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    pm's responded too, bump ^_^
  22. AthlonXP
    AthlonXP Pick your own.....you deserve it.
    20,437
    Oct 14, 2001
  23. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  24. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  25. yapchagi
    yapchagi Limp Gawd
    400
    Sep 7, 2012
    anyone knows if someone has 2x GTX 1070/1080, would he be able to get this promotion 2 times to get both games?
  26. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    Honestly...Not sure. I know you have to disable SLI to redeem...As it conflicts with the redemption process. What I'd actually recommend to do, is remove one card...redeem, swap cards, and redeem the other. Just to make sure everything goes without a hitch. For this process I'm 99% sure it would work. But for redeeming both back to back with on the same system with SLI 1070's or 1080's...I'm not sure. Let me know if you have any more questions ^_^.
    bump
  27. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  28. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  29. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  30. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  31. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  32. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  33. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  34. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
  35. hakstarr
    hakstarr Limp Gawd
    222
    Mar 29, 2011
    If you have anymore let me know PM sent
  36. gsilver
    gsilver Gawd
    518
    Oct 12, 2010
    I have two GTX 1070s (same PC, but swapped the installed card so that only one was installed at the time) and was able to redeem two codes.
  37. gs274
    gs274 [H]ard|Gawd
    1,110
    Jul 5, 2005
    So even if you meet all the hardware requirements, you still have to have the GeForce Experience POS installed? Or is that just for initial redemption?
  38. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    bump, pm's responded. It's just for the initial redemption. Once it's redeemed, you can uninstall GFE with no worries. It's use to verify system hardware/sn, and the portal to redeeming through uplay.
    Really dislike what nvidia has done though...As I would prefer not to have to install the atrocity known as GFE =*(.
    gs274 likes this.
  39. H-street
    H-street [H]ardness Supreme
    4,492
    Feb 25, 2005
    Pm sent. Looking for 2 of the ghost recon codes
  40. Ikasu
    Ikasu Gawd
    800
    Jul 24, 2007
    pm's responded. Almost out guys...grab'em while they are hot ^_^
