Freaking bitcoin
Discussion in 'Power Supplies' started by TurK-FX, Feb 4, 2018.
  1. TurK-FX
    TurK-FX 2[H]4U
    2,357
    Jan 21, 2009
    I sold 2 PSUs Las year for $140 and $160. It was Rosewill tokamak 1500W and EVGA G2 1600W. They did not sell for months and finally some one bought them. I was in need of a second PSU and I was shocked when I see the prices. I actually bid on eBay for a used Corsair AX1200i which HAS $299 MSRP, it sold for $490. I don't understand how Bitcoin rush can even surge the PSU prices. You use a PSU for about 5GPU. May be a little surge OK but double the prices? That is insane.
  2. Hagrid
    Hagrid Kyle's Boo
    7,774
    Nov 23, 2006
    Running 5-12+ GPU's requires lots of power. 1000w and above seem to be overpriced and/or scarce.
  3. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,839
    Jan 1, 2008
    1000w power supplies are typically very low volume products and manufacturers aren’t ready for the mining surge.
    Armenius and Speedeu4ia like this.
  4. TurK-FX
    TurK-FX 2[H]4U
    2,357
    Jan 21, 2009
    Even 750W PSUs now went up because regular Joes cant find the 1000W in stock and they have to buy 750W or so. Well. I dont think this will change anytime soon. Probably we will ride this another year or 2 at minimum.
  5. Ocellaris
    18,839
    Jan 1, 2008
    I just bought a 750 watt power supply for $95 before a $25 rebate. Do you expect 750s to be free or something? Are people blaming miners when toothpaste is out of stock too?!?
    https://m.hardocp.com/article/2017/01/18/thermaltake_toughpower_grand_rgb_750w_psu_review/
  6. TurK-FX
    TurK-FX 2[H]4U
    2,357
    Jan 21, 2009
    I am not blaming the miners. I just started to mine myself as well , LOL. But I used to buy good quality 1000W PSU for $130-150, not 750W gold rated PSUs moved to this price range.
  7. Aluminum
    Aluminum Limp Gawd
    447
    Sep 18, 2015
    I bought around a dozen seasonic plats and titaniums in the last 6 months or so before they got nailed by this. You probably don't want to know what I paid for some of them ;) I camp the deal tracking sites
    They seemed to lag gpu gouging by a month or so. Not that it takes a real genius to know if gpus are in short supply related products will be affected but boy do I feel smart. I'm unloading some of my older gold/whatever/unrated out of warranty to said miners.
  8. DTN107
    DTN107 [H]ardness Supreme
    4,544
    Jun 30, 2008
    Wow... I actually gave away a brand new Corsair HX1000i to a buddy a few weeks ago. It was from Corsair warranty but it was a brand new factory sealed unit that I kept in the closet for a couple years (forgot about it).
  9. ajrettke33
    ajrettke33 [H]Lite
    109
    Dec 7, 2014
    Take it back DTN!!!
    lol, yeah mining has hit high efficiency and high watt PSU's pretty hard....now back to my mining
    Ocellaris likes this.
  10. dexvx
    dexvx Gawd
    784
    Aug 14, 2002
    Is there a reason why people just don't run multiple PSU's? Seems to make more economic sense running 2x 750W than a single 1500W.
  11. Aluminum
    Aluminum Limp Gawd
    447
    Sep 18, 2015
    Multiple has other considerations, yes it is viable and can work but it tends to fail harder when it does.
  12. odditory
    odditory [H]ardness Supreme
    4,709
    Dec 23, 2007
    Server's PSU's. I used to have dozens of Corsair AX1200i's. Sold them all and replaced with HP and Liteon 1200W and 1400W server PSU's that I sourced for around $25/ea. + $12 breakout board + $3/ea for 6+2pin PCIe cables. Godsend.
    The thing with mining is avoid what the herd is doing.
    Spades45, Aluminum, Armenius and 2 others like this.
  13. rive22
    rive22 [H]ardness Supreme
    4,589
    Mar 10, 2004
    Yes, dual PSU setups are common.
  14. Aluminum
    Aluminum Limp Gawd
    447
    Sep 18, 2015
    Yeah good call, they also know what they're doing with the N+1 designs unlike some of the ATX DIY stuff.
  15. Spades45
    Spades45 Limp Gawd
    139
    Aug 19, 2011
    I am looking to power 2 new builds and want to go this route. Can you point me a bit closer in the right direction?
    What server PSU makes/models I should specifically look for or avoid?
    And same question wrt breakout boards/cables?
    Thanks
  16. somebrains
    somebrains Limp Gawd
    351
    Nov 10, 2013
    I blame the miners, PSU sizes were dropping from 1k-1200w down to 750-850 for a while. Who wants a long PSU when GPUs became less hungry around gtx7xx?
    I grabbed a spare 1000w when they were on blowout for $75 a year or 2 ago with a $25mir
    My Seasonic 860 decided to go tonight when I was popped in 64gb of 3200mhz and decided to see if I could retain my clock.
    I'm glad I had it bc I paid the same for a used 7700k what a psu runs now.
    Sucks man.
