Just so you know, the EVGA hydro-coppers are the same as the swiftech komodo.
So chances are, if the swiftech komodo did not work, EVGA will most likely not work either.
They are just a rebrand.
Not going to lie, most of the time I just skip over the writing and stare at the photos. Those fittings look freaking sweet.
I cannot wait to get them in my hands and check them out - yeah, whomever created these knew watercooling and the chewed up fingers that go with compression fittings. So I am anxious to try them out, I love new innovative ideas and the advancement in ways and areas otherwise thought to be just what it is. Kudos to those guys, I love supporting fresh new ideas and if they work well for me, I have no qualms in shouting to the world wonderful accolades to the revolutionary design I believe them to be.Those compression fittings are cool. Nice build.
As you can see from the images above, I have both a cheap roll of knock off carbon fiber wrap, which is a 24" x 48" roll and the more expensive 3M kind. That was $18 each and I have two. That is the cheap stuff that I will use on my desk. The 3M DiNOC stuff on the other hand is crazy expensive I think. For basicaly the same roll, it was like $38. Handling it though, its obviously worth the extra. The cheaper is more like plastic thin paper, where the 3M stuff is nicely textured and thicker and most certainly plyable vinyl. The quality and difference is night and day, so if you can go 3M do it. No I have not seen the red. I may check it out though, maybe use the red instead of red paint to do the accents - now there is an idea........Cav, have you seen/tried out 3m di-noc red carbon fiber? Thinking about getting some for my desk/computer depending on cost.
I have the white version of those fittings. They are great to work with.
Loving the attention to detail and the carbon fiber looks nice.
Your work is inspiring me to at least clean up the wiring in my rigs. Well, that and it's a nice outlet for stress.
Congrats on making the Front Page!
UPDATE: OK, you convinced me, I just ordered the red as well. $40.38 for a 4ft x 2ft roll + shipping on eBay. Will supply pics when it arrives and will let you know how it does when I get to start working with it.
Cav, do you mind telling us what desk it is you are using?
The red one w. your 27 inch monitor on it?
You'll figure this out when you get it but the red di-noc is based on white film so shows white on the edges. A red sharpie covers it well but is a pain.
Steve
I think you should do the laser cutting. That would be sweet with the back lighting. I am very interested to see how that case will turn out!
your builds are pure hardware hedonism.![]()
What exactly are you looking for? Maybe I have already posted it in the Frank 2011 thread. If you can give me an idea of angles or things you want to verify I can try to see if I have done pics before that will answer or if I need to do new ones. I hesitate on new ones right now tbh because everything is so jacked up waiting for this build to progress.Cav, do you mind trying to post some pictures of your desk setup. I looked at the provided link, but it only has one really low res aerial shot of it. Thanks.
Red & Black - lol, I painted and combined two desks.
Meritline Computer Corner Desk
http://www.frys.com/product/4491056?site=sr:SEARCH:MAIN_RSLT_PG
Mfr: COMPTREE Model: B-007
FRYS.com #4491056 UPC: 834784011118
I actually have taken two of these desks, the long side of both to create the current desk. The keyboard tray is a side to a shelf I used to have that sat on another desk that I used in place of that little short keyboard tray. As you can see I have another board on top of that right now because I need more room there. That will replace the old board under it. All I have to do is attach the board you see to the rails and drill new holes to mount it under the desk. This will happen when I mod the desk or when the board pisses me off enough because I am constantly having to adjust it to stay straight until I get around to changing out the boards. I plan on doing the carbon fiber wrap on it as well.
Steve, much appreciated on the potential issue I may face and the easy solution to it. That is what makes these forums so awesome is the feedback and bi-directional learning we all gain and give here. Dude +1 to you - thanks.
Thanks for taking the time to take the pics.
So excited!! Where did you find the cable management loops with adhesive backing? Those would go great for my desk management without using the screw in zip ties I bought at work today -.-
I like how you were using an Eclipse II wrist rest with your Cyborg.Two of my favorite KBs.
Those handles are serious business.
I was thinking about your carpet shedding problem (giggity), and though I'd toss in a rec for Home Depot's plain old indoor/outdoor carpet. I dont' know what dimensions you're looking for, but I think they have a range. It's very very close weave, plastic fiber stuff in neutral colors (I think they have a muted red), produces almost no lint by itself, and vacuums up very clean (or at least, it does with my dirt devil). I got an 8'x6' of it to go under my desk/chair pad, for around $20, and I've been very pleased with it.
I feel like with so many fans this case might get a little loud?
Also the watercooling stuff goes right over my head haha. Can't wait to see you start to build this.
Did you notice the fans? Those babies at full throttle do 15db, meaning they are quiet in comparrisson to most case fans which are around twice that noise level or more. I plan on running them 1/2 speed for daily running, so that should net me around 10db or virtually silent. Now moving to the front of the case, I will have the ones I use now in there and I can say they run full speed now and I have conference calls and no one hears them, I game and no one hears them. Are they silent? No, but they are not bad. I have a contractor grade bathroom vent in my private bathroom behind me, I can hear it running over Frank that sits next to me. Frank currently is running 3x Push/3x Pull 120mm Xigmatech Crystal Series fans that do 18dba each. I also have 3x 140mm fans in there that do 20dba each and yet another 120mm fan in there. Standing in the hallway between my office and the loft where my wife's office is, I can hear her OEM case fans running louder than Frank in my office.
So yeah, it may appear to be a ton of fans, yes I will be moving a ton of air, but I think its going to be tollerable if not minimal. This is why I will be using fan controllers as well to run most of them at 1/2 speed, that should make them all virtually silent and only need to go full bore when I game for extended periods or benchmark or am doing some rendering, which most of the time the Razer headphones are cranking, so IDC about the noise tbh, I won't hear them anyway.
I wish I had the money for one of the cards :/ would love to help fund franks upgrades![]()
Have they seen the magazine cover the last Frank was on? I think it would be beneficial to them to get it expedited for a chance their products would be featured on the front page of a major publication.Mountain Mods will be hopefully solified tonight and things in queue to be built, so we are about 4-6 weeks away unless they take pity and decide to get it going sooner - hmm, wonder if a petition from multiple parties would assist them in bumpin gup the priority of this mod?
