Mue,
The Thermaltake said I should have a 1569W PSU min. This is with overclocking I plan on as well as with the following:
Core i7 3930K
1x DVD/RWCD DVD ROM
1x BR/DVD/CD Burner
6x 120mm led fans
3X 140mm led fans
4x SSD
2x 7200 SATA
2x 1,500 SATA
4x GTX 580/SLI
4x Cold Cathode
5x USB Devices that draw power
8x DDR3 DIMM
2x DD D5 12v Pumps
1x AgeiaPhysX - not that I will be using one, but nothing allowed for a 6-pin power requirement for the Phoebus Sound card, so I chose that.
Realistically the 1600W isn't enough - crazy huh? Glad I have a 30a dedi circuit for Frank - he is going to need it.
Glad you enjoy the pics and the text. I do enjoy taking and cleaning the pictures for posting, so images are certain in my posts - I love photography as another of my hobbies second to PC building/tweaking and FPS gaming. So thanks for the kind words and check back often.
Its entirely enough, At max load you'll be abit lower then what that Tt calc says. Under full load (Folding,Furmark+Prime) You'll be at about 1400-1450w. So you have abit of overhead. That being said, you could make a pretty penny and sell of those 580s, and grab a duo/trio of 680s and have equal performance and a significant reduction in power consuption.
Regardless though, the build looks great. Hope you're havin fun!
