IndianScout
- Oct 27, 2004
They STILL have not fixed flat panel scaling for the Benq FP241W and WZ. Seriously, the monitor has been out since November, wtf is taking them so long?
No support for 7100 GS?
NVIDIA used to have the best video card drivers, now they suck ass and are inexcusably poor.
It has nothing to do with the monitor, but rather the whole feature is still broken. It doesn't work on my Dell 3007WFP either or either of my Viewsonic monitors.Direct X 10 SLI support not being fixed is just laughable and stinks of incompetence. I know we don't need that feature yet, but the fact that it is still broken is just retarded. NVIDIA STILL does not quite have their act together on their drivers.
Flat panel scaling needs to be fixed.
Believe it or not Flat Panel Scaling does work for some monitors. With my Viewsonic VX2025WM the flat panel scaling settings don't do squat - never did. But they work perfectly on my BenQ FP222W. I really wish nVidia would get their asses in gear and fix this bug - it's literally over a year old. Since the 90 series drivers came about anyway.
I'm having some problems with these drivers, nothing major. With the 101.70 drivers, I had no problems whatsoever, but with the 158.19 drivers, smooth scrolling in Firefox or IE7 was choppy, almost like the CPU usage was 100%, when it was only a few percent. Uninstalled them, restarted and reinstalled them again, with the same results. Uninstalled them and went back to the 101.70's and no more problems.
Odd, I've not experienced this issue. Presumably you used Drivercleaner when you removed? Not sure how much faith to invest in it, but it is something that you get asked in these situations!![]()
Per nVidia's documentation, this is how the drivers should be installed. I rebooted each time I performed a step:
1. Uninstall current drivers. Reboot.
2. Install new drivers. Reboot.
3. Uninstall new drivers. Reboot.
4. Reinstall new drivers. Reboot
Worked like a charm.
Installed 158.19 from 100.65 and now I get a blank screen once Vista starts up.![]()
Put 100.65 back on and it's fine.
XP x64 performance dropped like mother. BF2142 framerates dropped from 50s to the teens w/ the new drivers.
BUT, recently I had a problem w/ my XP / Vista dual boot where my boot partition got all screwed up and now my X-fi is wigging out in-game after a while. I guess it's time another round of reformatting...I'll try again and see how these new drivers work in 3dmark and bf2142.
Umm, Vista drivers are 158.18. Unless you mistyped, you were trying to use XP drivers, buddy.
It has nothing to do with the monitor, but rather the whole feature is still broken. It doesn't work on my Dell 3007WFP either ......
Scaling works perfectly on my Dell 3007WFP. I installed the 3007 drivers through windows update and it started working.![]()
That started working for me as well when I did the same thing. So at least that's something. The drivers seem to be pretty decent for the most part. I have few complaints. NVIDIA is moving in the right direction, it's just taking too long to get where they used to be with their other drivers.
I just ran 3dmark06
Here are my results
(running Windows xp)
97.94 - 12014
158.19 - 12572
I gained 558 points!!
