using a xiggy dark knight, gskill ripjaw ram (2x2GB), and ga-p55-ud3r. HS can be installed any which way (couldn't find this info so i figured i'd post it).
using my HS to push hot air up to my giant ninehundred two top exhaust. my rear 120mm exhaust is now intake and rather than pushing hot hard drive into my case i am pulling it out with both 120mm up front. seems like the only downside at this point is i am only using one 120mm intake compared to the two 120mm and the big boy atop the ninehundred two for exhaust. doesn't look like a 120mm will fit on side window for an additional intake with the heatsink mounted the way it is.
~5C temp drop...not too shabby for moving a heatsink and flipping some fans around
(also moved my gfx&sound cards closer to the PSU)
curious as to what everyone thinks about expelling the hard drive air (using both 120mm front intakes as exhausts) and any suggestions or improvements for intake as I am only currently using one 120mm
