- Oct 12, 2004
After receiving a Q6600 sold by a fellow folder here, I installed in the HTPC computer (Asus P5E-VM HDMI in a Lian Li PC-A05B). Shortly after, the motherboard has decided it's time to do a seppuku and burn the northbridge. Since it's my second motherboard failing on that HTPC, I decided it's time to kill the LGA775 plateform and go on a new one.
My goal is to have a powerful but power efficient HTPC computer which can fold as well. I don't have a unlimited budget so here's what I came up :
EVGA H55V micro-ATX motherboard
Intel i5-650 (to take advantage of the integrated graphics and hyperthreading).
Mushkin Enhanced Silverline DDR3-1333 2x2Gb
Corresponding LGA1156 waterblock (probably a EK Supreme LT)
Total should come at about 400$ so I'm asking if there are things which must be changed to optimise folding performance. I know I could go to a i7-860 or even going to AMD (if that's the case, I don't know anything about it so suggest a good setup).
EDIT : After doing some research, it seems the EVGA H55V have no much overclocking options and since I don't want to touch Asus again with a ten foot pole, what's left was Gigabyte and MSI. I found a Gigabyte which better match my needs in the GA-H55M-D2H, still checking.
