Scaling doesn't seem to be dependent on price anymore - there are cheap monitors that will do it, and expensive high-end ones like the 30" that won't do it. ATI really needs to do this like NVidia so that there is no more of these "Will it scale" questions.
But its broken on Nvidia drivers.![]()
does it work?
Sigh.
Don't you suppose you should read the thread? I have an 8800 GTS/1680x1050 LCD/XP-32, and a 8600GTS/1920x1200 LCD - scaling works with the 163.44s.
It has also worked for me with the 162's, and the 160.03's - you just have to use the overscan compensation hotfix.
It isn't broken. I've posted about 8 times in the nvidia section on how to fix it. If it isn't working for you with 163.44, look in the latest thread, and apply the steps I outlined.
Thread is here
It doesn't work PERIOD with ATI, which is a hell of a lot worse than "doesn't work until after I apply the overscan compensation fix"![]()
In a nutshell, most WS monitors simply stretch whatever input is given them, especially over DVI. This is not good when you want to play a game that only supports 4:3 or 5:4 res since the image will be distorted horizontally. What fixed aspect ratio scaling does is introduce pillar boxes on the sides of the image for non-widescreen res while scaling the image to the monitor's top and bottom keeping the aspect ratio of the image intact. The big deal is that DAAMiT refuses to even consider implementing this into its desktop VGA line despite many requests to do so for the better part of two years or more, but to add some confusion, they support this feature for mobile VGA under the label "maintain aspect ratio" in CCC that simply does not appear for its desktop VGA.
It works with my two widescreen monitors. Did you apply the fix and then reboot? Did you uncheck treat as HDTV?
I play Diablo 2 still, and refuse to play with a stretched desktop. It is a very big issue for me, therefore I *KNOW* it works with my 8600 GTS and my 8800GTS.
It isn't a ghetto fix to apply a manufacturer supplied patch...it is a manufacturer supplied fix. It works if you actually read the thread and try it. If it isn't working for you, then perhaps a complete uninstall/reinstall of your drivers are necessary, then apply the overscan compensation fix, reboot, and then uncheck Treat as HDTV, and your flat panel scaling options are there.
As I said before, I'd far rather have it work after applying a fix than have it to never work at all. If it still doesn't work for you, then perhaps you can get an ATI card and bug AMD to integrate it into their drivers. Good luck, because for the longest time they have claimed that it is impossible to do, and yet I've been doing it with my NVidia cards all along.
Patch and notes are here
The fix is for Windows XP. I do not know if it works under Vista. Perhaps you could install it and post back to let everyone know.
