ZL1 said:oh I misunderstood, I thought you were talking about what vcore is being supplied by the mobo if bios is set to x.xx
ur complicating things man, you really dont have to figure out the vcc, just run prime and if prime fails it means the vcc dropped too low and the cpu missed a 1
D
I don't get errors in Prime, that is the problem it just locks... I'll be interested to see the impact of the DDR500 ram on this system.
Using memtest I've determined memory max is 225mhz, and timing of 2.5,3,3,8 ran for hours without a single error.
So then I played with the 5:4 ratio and could not get it solid over 242, just staying stable period... not pushing the cpu with prime or anything. Just to see what the max FSB I could set it at period... everything above 242 would reboot.
Ah well more fun on Tues when my memory comes in!
