- May 2, 2006
For poops and giggles I am thinking of replacing my top mounted gts 280 x flow and putting a gts 280 u flow on the bottom of the case so both radiators are intake side.
I am looking at going full water cooling for the first time, so far I am looking at
pump/reservoir - xspc d5 photon variable speed/sata
cpu block - xspc raystorm pro AM4
radiator - hardware labs nemesis 360gts + nemesis 240gts
gpu block - ?
fittings - bitspower
tube/size = ?
I will be cooling a ryzen 2600x and reference vega 64 in a corsair air 740 case, aiming for as cool and quiet as possible, nothing is set in stone so any recommendations or advice is appreciated.
The one on top? I didn't find it too much of a hassle myself.
Ah, ya, it would be a pain without a squeeze bottle.
Just pulled the trigger on the case, I was going to get a second reservoir, is there any issues with running 2 reservoirs and one pump?
No, you can configure your loop however you like without affecting temps.
Got the second rad installed, messing with fan profiles now, playing BF5 for 2 hours I am getting these results...
Ambient temp - 72-74f
Water temp - 30-31c
Vega 64 - 44c
CPU - 40c
Fans spin up to about 1000 to 1100 rpm, trying to figure out what to run the 3 exhaust fans at to have optimal noise/heat removal. I also realized I have a spot for one more 140mm fan to blow air over the GPU/MB.
What are you using to control the fan speed?
Corsair icue with a commander pro, got a fan splitter and am running the 8 radiator fans off 1 channel.
Using an inline water temp sensor before the pump, fans run at 600 rpm up to a water temp of 30c, 800 rpm at 32c, and 1200 rpm at 35c.
With those settings the highest my water temp hits after an hour of gaming is 32.5c, vega 64 hits 49c, and ryzen 1600 hits about 42c, fans hit about 850-880 rpm.
Corsair commander pro, channel one on the commander pro controls the splitter for the 8 rad fans, the other channels on the commander pro control the case fans.
I thought about putting another inline sensor on the inlet for the first radiator. With 2x 560mm radiators the fans don't have to move much air to keep everything cool.
I thought about getting an Aquaero, but with water temp maxing out at about 32c with my fans running at 800 rpm I don't know if it's really worthwhile.
If I run my fans at a flat 600 rpm my water temp max while gaming is about 33-34c and my vega 64 hits 50c, at 800 rpm u see a max of like 32.3c water temp and 47-48c on the video card.
According to hwlabs, the radiators I am using can dissipate up to 2500 watts, and I am using two of them.
One of the primary selling points for the Aquaero is the fact that it is fully standalone. If you so desire, you can install it, configure it, then unplug the USB connector and uninstall the software. The controller itself saves your configuration and will run independently of your OS. Also, it makes it so you really don't have to worry about what fan control your motherboard comes equipped with. The Aquaero is almost guaranteed to be more powerful, more flexible, and more robust than what any mobo has embedded. It's nice to not have to care about that when shopping for your next platform upgrade.I thought about getting an Aquaero, but with water temp maxing out at about 32c with my fans running at 800 rpm I don't know if it's really worthwhile.
