Bummer you didn't catch them on sale, for some reason Fry's has them on sale about half the time...
The pump is up by the res, right? You might quiet it down with a small piece of foam under it, depending on the noise you are getting... I use a different pump (sits on my power supply), and in at least one version of the loop I needed foam under it to decouple from the metal.
