- Oct 7, 2000
you might get away with that short tube. now that I see it straight on, its basically the same offset either way, so you'll get the same kink. from your other pics it looked the bottom right port was straight below the top left port. if you have a bit of hard line left you could put connectors on each and heat the entire length to soften it a bit and just slightly lean it into shape.
otherwise, fill it and try it.
as far as that pad goes, it looks like it made zero contact. is that block universal? make sure your mounting posts are the correct height. id use your AS5 to make sure its getting correct contact.
