Hello I am new to the world of building computers and was wondering if you fine gentlemen could help me out by giving me your excellent advice. I have never built a computer before and am excited at the prospect of it. Not looking to build the greatest rig in the world but a decent one. I've been using a compaq with a pentium D 1.6ghz, 2gb of ram, and a Radeon HD 2600 for about the past 5 years so anything is an upgrade at this point. First lets answer the required questions:
I will use this computer for web browsing, watching videos, and gaming mostly. I'm looking into getting into Photoshop a little as well, not sure how that changes the system.
My Budget is under 1000$ (US) including tax and shipping.
I live in Indiana, in the good 'ol US of A.
I need a power supply, graphics card, SSD, memory, HDD, cooling solution, optical drives.
Won't be reusing any parts but I have already purchased my CPU, mobo, and case.
6) Will you be overclocking?
Not at first, may look into it in the future.
7) 7) What is the max resolution of your monitor? What size is it?
I'm using a AOC led tv as my monitor. I believe its 25" and the max resolution is 1920x1080. Will look into upgrading this in the future, hopefully to a 2 or 3 screen set up.
Within the next 2-3 weeks. Was planning on pulling the trigger on the psu or ssd I was looking at in the next day or 2 because of their prices on newegg currently.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Have already puchased this: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837&Tpk=p8z77-v%20lk.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes I do. Purchased it through school, I believe its professional 64 bit. Not 100% sure but if its not I can purchase it through my university for around 30$.
Alright, that takes care of that. Now I have picked out some things based on what I've read/researched and would like you gentlemen to critique that as I defer to your knowledge/experience which is far greater then mine.
I have already purchased the above mentioned motherboard and a intel i5-3570kk processor. (I happened to be in Chicago near a Microcenter). I also have the Corsair 500r as my case that I've already purchased.
The following is what I've been looking at:
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233206
HDD:http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891
Optical Drives: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 and http://www.newegg.com/Product/Product.aspx?Item=N82E16827136250
With 2 day shipping currently on Newegg that puts me right at $992.36. I understand that prices are subject to change the longer I wait.
My main questions are about compatibility. Will all of these components work together? Is the psu strong enough to run everything? Would that psu be able to run that video card in SLI if I chose to go that route later on? Are any of these components/companies complete garbage and I should stay away from them? Any advice will help immensely, again I defer to your wisdom.
Thanks for the time gents!
