Hello to All,
I need to keep my cost down the build I have now is listed here: http://hardforum.com/showthread.php?p=1036061624&posted=1#post1036061624
I posted it in the wrong thread.
Below is my updated build from input I got from my first thread:
The Build:
- Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B - OEM
- COOLER MASTER RC-692-KKN3 CM690 II Basic Black Steel ATX Mid Tower Computer Case
- Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
- EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (Got this FREE)
- CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
- Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate
- G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
- ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
- AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
- Microsoft Windows 7 Home Premium 64-bit
New total is around $659.00 & thats great
Most of the posts say my graphics card holds me back Im sure thats true but it was free and I can all ways upgrade my graphics card in the future right? The screen resolutions Im at now is 1680 x 1050.
I dont play that many games that requite I major graphics card.
Games I play are Left 4 Dead, TF2, Counter Strike, StarCraft 2 and other simple ones like that that dont need a major graphics card but on the other hand I want to be able to play them at medium to high setting like StarCraft 2. Can this be done with the setup I have? Also do you think this setup will last me the next 5 years? I might up-grade the graphics card but do you think I will be good on everything else I listed?
I know I said a lot but any input is help full
Thanks
The Build:
Thanks
