- Dec 5, 2018
Clearly.
Good to see you are having fun with it.
For me, I set my PPT/TDC/EDC to 200/140/180, boost override to +150, and a negative all core curve of -28.
All cores will hit 4800MHz, and with a heavy all core workload you should see 4600-4800MHz, depending on what's running.
You could try for the full +200, you might be able to nail it down, but I wasn't able to do it in a stable fashion.
It will not use the full power settings that I listed, so no need to worry about fires.
I spent some time to find out what the maximum power the socket would allow the CPU to have, and for how long, then I set my curve to match my boost. No need to touch VCORE at all.
Alternatively, you could try to find the max static OC that you can achieve, but chances are in SC stuff you can get the CPU to boost about 100MHz or so over static numbers.
Edit:
I also wrote down those max socket numbers, but lost the paper.. so I just gave it a little dose of 5900X power settings.
Edit again:
Best I could do with static numbers was 155w PPT, not bad for a 65w part.
You're not an asshole, I don't know why you would be, I just don't understand whether the processor gets more voltage with a negative offset of -25 or with a negative offset of -28, for example, I don't understand again.Ok, just to show that I am not really an asshole, here is a direct quote from a post I made on another forum from someone asking about 5600X OC. This was my reply less than 5 mins ago.
Thanks, I am kind of loveable once you get to know me.You're not an asshole
The lower you go, the more voltage it gets while trying to push the core harder upwards. Positive curve has the opposite effect.. sorta. The curve works in conjunction with your power limits. Not enough power to back the curve at the commanded clock, and it will crash.I just don't understand whether the processor gets more voltage with a negative offset of -25
You cant, those were static numbers I think. I kicked the shit out of my 5600X, and she loved it. It is running in my sons system right now, and I am low on TIM or else I would demonstrate for you. My 5600X is stable at 2000 1:1.. good chip.. has been to 2100 1:1 a few times. this page has all 3 of my CPUs running aida64.. its an old, long running thread..But I'll try to copy your numbers and run Cinebench R23
Maybe to a point, but the CPU is very easy to drive. 130w PPT with tuned PBO is mighty impressive, trust me.. you dont need a sledgehammer to kick it in the cores a little.And another main influence is the motherboard
What numbers should I put for PPT, TDC and EDC then?Thanks, I am kind of loveable once you get to know me.
https://www.techpowerup.com/forums/...y-benchmark-here.186338/page-102#post-5060353
Oh those numbers.. yeah you can use em.. 200/140/180.What numbers should I put for PPT, TDC and EDC then
Out of those two I would probably run the Venomous.And which air cooler is better, has better performance, noctua nh-u12s or thermalright venomous X?
https://www.thermalright.com/product/venomous-x/Oh those numbers.. yeah you can use em.. 200/140/180.
It will be fine, it is an easy CPU to cool.https://www.thermalright.com/product/venomous-x/
I mean this old X, so that there is no confusion
I don't think it's better than the noctua nh-u12s, as far as I can see, it's all similar.Sweet. I have Le Grand Macho RT and True Spirit 140 Power, and an AM4 mount for them. But I prefer their newer coolers. Right now I am using one of their AIOs.
no one mentioned mx5 until you did... but yes, it does break down and thats why it was pulled. use 4 or 6 instead.As for the paste, I don't really like this MX5, it's somehow too thin and seems to be falling apart.
I still have an MX4 and I have the noctua nth1, the first version.
I put the MX5 on again. It should have the best performance.
RDR2 crashes again when msi afterburner is running, my card was undervolted but it doesn't work anymore with that in rdr2, they broke something with the drivers again.
I didn't know that, they withdrew from production and sales?no one mentioned mx5 until you did... but yes, it does break down and thats why it was pulled. use 4 or 6 instead.
its because youre undervolting...
i thought it was pulled, looks like its still for sale some places. yes it seperates in the tube. on the cpu youll probably see early pump out. itll work, just not as long as their pastes usually do.I didn't know that, they withdrew from production and sales?
Is it dangerous to use or what? I recently put it on
It seems that those settings don't work for my motherboard and CPU, I put that in, ran cinebench r23 and in a second the computer crashed.Oh those numbers.. yeah you can use em.. 200/140/180.
