nightmare75
- Mar 13, 2009
This is my first real attempt at overclocking here. I had a goal in mind of hitting 3.6 GHz with my Q6700, but I'm a little concerned about the voltages I'm going to need to get there.
Currently, I've got it running at 3.5 GHz (350 x 10) and CPU-Z shows 1.4v (it's about 1.43 or something in the BIOS) and my RAM is running at 421 MHz. I've got my NB and RAM overvolted by .04 v apiece. Temps are also starting to concern me at this point. Idle temps are fine; I'm getting ~38 C on all four cores. When I run P95, they hit the high 60s, occasionally touching 70 C.
The last few times I increased the FSB, I've had to up my vcore by .03-.05 volts to keep it somewhat stable. I know the processor is rated by Intel to be safe to 1.5v, but I'm a little worried about approaching that. How much higher can I increase the voltage before I should start worrying about having too much?
Additionally, how much benefit could I see from adding more voltage to the NB or the RAM? Would adding more voltage to either of those prevent me from having to add more to the vcore? My RAM is only rated to 1.9v, so I don't have a whole lot of room for increasing voltage there.
And finally, how much higher should I be able to go with the temps before I have to start worrying about being too hot?
I would like to mention that I'm mostly overclocking this far for benchmarking runs. For everyday use, I'm probably going to dial it back to about 3.0-3.2 GHz.
