Manny Calavera
- Jun 10, 2004
they used a zalman 9500 mentioned on the overclocking page1.6 V !!!!!!! no mention of what cooling was used and what the temps were. Bit too much Vcc for my tastes but once the price drops it sure looks like a fun one to play with.
My only gripe with this review: the conclusion is spastic.
"Performance of the Core 2 Duo E4300 isn't that impressive as that of the senior models of the series. Although it differs by only 3-5% from the Core 2 Duo E6300, the new CPU is slower than the Pentium D 945 and Athlon 64 X2 4200+, which cost about the same money, in some benchmarks. But there are few such benchmarks and the new CPU is far more economical than any of its opponents."
Err... actually, in most of the tests the E4300 is as fast or faster than the PD 945 and X2 4200+.![]()
/drools
Great chip for those on a budget with cheap DDR2-667 memory (me, basically)
Actually, I would like to see more benchies. I'd like to see a OCed 4300 versus an OCed 6300, maybe an OCed 6600, as well as a 2.4 4300 versus a stock 6600.
this will definitely replace the 6400 as the preferred overclocking chip.
the 6300's were too hard to overclock b/c of the low multiplier (high FSB needed)
the 6400's were good
the 4300 will be PERFECT! Low price, higher multiplier! It will give you the option of 400x9 = 3.6Ghz if you have a nice chip, or 400x8 = 3.2Ghz if your chip isn't quite that great.
I can see a lot of people getting 100% overclocks in the future! I also see the AMD forum becoming empty & quiet after this.
This is going to sway the last few hold outs.
I like the 800mhz fsb, definitely leaves alot of room open for even a weak board to OC.
That's what this CPU is all about...![]()
Get a CRAPPY (!!!!) Via hybrid (AGP + ePCI + DDR1 + DDR2) mobo for ~$50, get the E4300, set the FSB to 266 and you got yourself E6600 (minus 2MB cache) upgrade for ~$200... Perfect for all on tight budget... Last time I checked, 2.4GHz C2D's still destroy anything AMD's got to offer... That will be the end to ANY "low-price" advantage AMD's got left today...![]()
Anandtech has a review up.
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903&p=1
3.37GHz @ 1.47V with the STOCK HSF! Pretty impressive!
With reviews pouring, we can see it doing 9x400 for 3,6 GHz as the sweet spot for the E4300 owners.
Am I missing something?, no one has had one running at 3.6gig yet, little own calling 3.6 gig a sweet spot.
It may simply not do 3.6gig, anandtech said...
""With a 9x multiplier the E4300 can potentially reach as high as 9x400 or 3.6 GHz while keeping memory at or below DDR2-800.""
Note the word "potentially", if it was so easy to hit 3.6gig why did they only O/C to 3.38 begs the question.
now the dilema arises: would it be worth the extra $20 for the 10x multi of the E4400 vs. the 9x of the E4300? i'm thinking that in April the E4400 will be taking the king of overlocking crown.
-bZjThe CPU was cooled with a Zalman CMPS9500 LED cooler.
Following the standard procedure we increased the clock rate of our CPU in 1.9 times! We achieved this without employing any special cooling means - we used an air cooler.
So when's it going on sale? It'll be replacing the 915 in my sig I guess![]()
Need something new to overclock![]()
Doesn't it bother you that it needs to be overclocked not to 2.9, not to 3.0, but to 3.38Ghz in order to match the X6800? A E6400 does that at 2.88(all according to Anandtech)
But for now they aren't much cheaper than a E6300...
what the hell do you expect with an 800Mhz FSB and 2mb cache vs. 1066Mhz and 4mb cache?
this proc is a damn good overlocker....and your COMPLAINING.![]()
