DefineByte
- Apr 24, 2006
I'm about to put together a new system for gaming (1680x1050) and general usage. Specs:
oft). Will it be sufficient?
This is all going in an Antec Solo case, which I guess is big enough.
I plan on using the stock cooler for now then upgrade to a Thermalright Ultra Extreme 120 if I find it too noisy/hot.
Is there anything in the specs you'd change? Am I forgetting anything? It's been a while since I last built a comp.
- Intel i5 750
- Gigabyte GA-P55-UD3R - I've struggled to find a board I like but I guess this one will do. Don't need RAID, crossfire or firewire but would like eSATA, 1 PCI slot, 1 PATA connector, well placed/usable PCI-E x1/x4 slot/s. I'm slightly concerned by the Foxconn socket issue but I guess it shouldn't matter with my usage. I'd like to wait for the P55A boards to come out (in the UK) but the mobo in my current system is on its way out so need to replace it quickly.
- Crucial Ballistix DDR3 PC3-10600 4GB kit (BL2KIT25664BN1337) - only because I've had good experience with Crucial in the past. May well be better buys these days
- ATI Radeon HD 5850 - probably XFX but not sure
- 2x Samsung Spinpoint F3 1TB HDD - seem decent for the price
