knightsilver
- Aug 5, 2008
The system posted the first time just fine to my relief.
Ill I changed in the BOIS is the Boot order and USB keyboard and mouse.
I cant get past the initail instal of Vista and its slower than dirt.
Gigabyte
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128380
G.Skill
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
Q6600(stock clock)
Sata DVD-RW(sata 0 port)
RaptorX sata(sata 1 port)
Geforce 250 1GB
PCP&C 750W
Thermaltake Typhoon HSF
And idel CPU temp is 38-40C
What other info do yall need?
Im sure its an IDE or stata thing?
thanks,
shane c.
Gigabyte
G.Skill
Q6600(stock clock)
Geforce 250 1GB
PCP&C 750W
thanks,
shane c.
