stop!theradio
- Jul 13, 2007
I would love to see 3D tech gain mainstream support, but until the television industry fully supports it with more than two channels of programming, this is dead in the water.
Sorry, but you will find backlight issues on any LCD, simply due to the nature of the design. A single light source is incapable of providing 100% equal coverage. The other problem, is that overbright/oversaturated LCD you see in the store? The bulb brightness dims far faster than plasma and will fade after just a few short years of use.
Burn-in on plasmas is a thing of the past. Pixel orbiters refresh the screen when the pixels remain static for a certain amount of time.
Black levels have always been a bigger problem with LCDs, because of the limited number of colors only allowing a limited amount of grey scale. Even on a "good" LCD, it will be difficult to make out the contrast on dark images. Look at someone with black hair in a night scene on an LCD compared to a plasma and the difference is obvious.
Bottom line, you are comparing a screen that can reproduce 1 billion+ colors at virtually infinite contrast without ghosting, to a screen that can only do a maximum of 16.7 million colors and a very finite true contrast ratio! Weight and energy concerns aside, Plasma is a superior technology in every way that LCD is incapable of ever equaling. People may try to justify to themselves that the shiny new LCD they bought at Best Buy is better, because they wanted to save a buck, but that is simply not the case.
No, you will not find backlight issues on any and every LCD. Perhaps the monitors YOU have had the displeasure of owning have given you that impression? Also, where did you get that LCD's burn out faster than plasmas? Both LCD's and plasmas have nearly the EXACT brightness half-life. In fact, it's only been recently that manufacturers have been able to rate their plasma life expectancy as high as LCD's. One nice thing about LCD's, as well, is the fact that the bulbs are replaceable, so once your image is half as bright as it used to be, you can make it like new again. Plasma? Nope. It's officially a piece of trash once the picture starts to dim. The colors get dull, the contrast goes to shit, and your blacks become grey. Also - burn-in is barely an issue, as you've said, and as I've said in my other post - but it's still a factor.
You're talking about "superior" technology. Since when has "superior" technology meant ANYTHING at all? That 1 billion colors that a plasma may theoretically be able to reproduce means jack shit when your video source is only 16 million colors. Other issues - color saturation. Way-too-bright Etc. The wonderful thing is that those can all be turned down. Those are non-issues. Now if the manufacturer set them all at ultra-high-eyes-bleeding mode settings, and made it to where the TV would kill my whole family if I tried to change settings - then we'd have a problem. Thank the heavens that's NOT the case.
If we based which display type was "best" on color reproduction alone, then we wouldn't have plasmas or LCD's, we'd still be using CRT's. But that's not all there is to it. A modern LCD is fully capable of displaying exactly what it's fed. It can reproduce every bit of the content it's given, faithfully. Sure, a plasma can theoretically reproduce even more...but by the time we have content that matches the abilities of a plasma, your plasma will be on it's last breath, ready to be thrown away, and LCD's will have far surpassed plasmas in every way.
